Bad sleeve on ball joint
Old May 4, 2022 | 09:40 AM
RBing's Avatar
Default Bad sleeve on ball joint
2007 XK
My upper control arm has a torn sleeve on the ball joint. I'm having a clunk from my suspension but thought it was the shock because I didn't get it torqued down properly. I haven't put back together yet because I'm wondering if it might be the ball joint. Will that cause a clunk when going over bump or is it just to protect the ball joint from getting dirt in it?
Old May 4, 2022 | 12:35 PM
guy's Avatar
guy
protection from dirt alone. And if the ball joint has lost lube…
Old May 5, 2022 | 06:59 PM
bocatrip's Avatar
Originally Posted by RBing
2007 XK
Rbing....Just for your information....if you decide to inspect the boots at the rear upper and lower control arms,rear outer tie rod ends, and rear sway bar links, you might see torn boots as well. It's quite common on our cars for the material Jaguar used for these boots to disintegrate over time.
Chuck Schexnayder
50
May 28, 2025 08:34 PM
funracer
Jul 15, 2019 10:01 AM
louismacrides
Nov 12, 2018 12:19 AM
auchman
Aug 25, 2014 03:52 PM
Goldlion
Jan 2, 2013 04:07 PM
