Battery is Dead Again
Old Oct 7, 2024 | 04:42 AM
Stuart S's Avatar
C2D47174 is not available for North American X150 models because it is part of the Pedestrian Protection System, which is standard equipment in Europe but is not available here. See Post #48: Pedestrian Protection System Warning ⚠️.
Stuart
Old Oct 7, 2024 | 06:21 AM
guy's Avatar
guy
Apologies guys…. but I’m in an anchorage in Virgin Gorda.
Battery spec attached.
Old Oct 7, 2024 | 07:51 AM
sony2000's Avatar
I think C2P0001 is visible just below the coolant tank and bolted to the firewall. Easy to work on.
Old Oct 7, 2024 | 10:56 AM
tommytess's Avatar
Default Alarm sounder
Originally Posted by wymjym
Does anyone else care to discuss the possibility that the sound bat might be the cause of so many dead batteries?
I never considered the clunk sound of the locks should also have a 'chirp'
Mine has never chipped and the battery has always been a monitored concern for myself. (Watching it slowly drop.)
Wj
Yes my new one chirps but the old one never did
Old Oct 8, 2024 | 06:51 AM
charger77's Avatar
Originally Posted by guy
i humbly disagree. If the car was in convenience mode for 20 mins and if that caused the battery to drain to 5v, the battery was on its last legs anyways.
Furthermore, your particular car does not call for an AGM battery. No, I am not saying that would be the cause of the failure.
But you could save some money and put the specified battery in the car. And get the same life out of it.
You aren't saying an AGM battery could cause any issues, right?; ...just that they aren't necessary and they cost more, right???
Old Oct 8, 2024 | 07:24 AM
sony2000's Avatar
Very often the problem with the XK are dead, dying, or low batteries. If you have a wet cell battery they will not take this abuse and will have to be replaced. But an AGM can take much more abuse and fully recover from it. So where is the savings in wet cell? If I recall AGM can drop to 10% and wet cell to 70% without damage.
Old Oct 8, 2024 | 07:54 AM
RichardS's Avatar
This is correct. I have a flooded battery in the XK8 but decided to go for an AGM in the XK as the XK8 is always on a smart charger when not in use whereas the XK is not, although neither car is a daily driver. It seemed that the extra peace of mind was worth the extra expense. However, I wouldn't say that the extra expense would be that worthwhile if the car was used regularly.
Richard
Old Oct 21, 2024 | 11:46 PM
  #28
indyx358's Avatar
Default Hazard Light Button On
I just walked past my XK, to let my dog out and I noticed my alarm light blinking and then I noticed my Hazard Light button is illuminated (red).
is that normal or could it be something I should be concerned about in regards to a slow battery drain?
Old Oct 22, 2024 | 06:01 AM
guy's Avatar
guy
Apparently, missed this one too.
You are missing an essential part of the narrative. The charging demands of an AGM battery are different from that of a wet cell. Your generator in this car is not geared for the maintenance of an AGM. If you go the AGM path in this car, you should keep it on a maintainer. (as many here do).
But not me. I get 4-5 years out of a wet cell battery. It is not kept on a maintainer. And frequently, she sits for 3 months, then starts right up. I’ve got better things to do than fiddle with the battery every day. And I have no patience for the car not being dependable and available when I want to use it.
Old Oct 22, 2024 | 04:23 PM
  #30
tommytarget's Avatar
Originally Posted by Stuart S
If you leave your Smartkey within 10 feet of your XK, the car will stay in Convenience Mode longer and could drain the battery.
Even though you bought that AGM battery in March 2024, you don't know if it was fully charged when installed or how long it sat on AutoZone's shelf discharging before being installed. Drive back to AutoZone when you can and have them load test your battery. They may decide to replace it under warranty.
Another possibility is that you're not driving far enough every day for your alternator to fully charge the battery, or the alternator isn't charging. See: Alternator Not Charging
Don't randomly throw new parts at your car. Get the Diagnostic Trouble Codes and follow the troubleshooting guide.
Good luck!
Stuart
i have made the mistake a few times of leaving the fob in the car for a few days and then returned to a dead battery. jump started and went for a long drive each time and the car was fine until i did it again. (slow learner)
Old Oct 22, 2024 | 06:27 PM
  #31
guy's Avatar
guy
Worst case scenario, convenience mode in my car ends in 33 mins. (as per the workshop manual) I occasionally leave the fob in for weeks. Ditto for the rear hatch open. No problems.
Old Oct 23, 2024 | 09:09 AM
  #32
interesting. i've left the fob in twice and my wife did once. all three times ended up with dead battery after the fob was in the car for a few days. and i never have problems starting otherwise.
btw ... super envious of your british racing green XKR ( i love my black one ... but my next one will be BRG )
Old Oct 23, 2024 | 11:18 AM
  #33
guy's Avatar
guy
That is odd. Again, not my experience. And its worked both ways... leaving it in the finger recess for the parking brake and leaving it in the dock.
I (and often strangers) concur, that classic colour combination just ages with grace. Best of luck however... I'm on a mission to find a couple of stable mates ;-)
jomo
Jun 8, 2020 06:31 PM
Jagstefano
Dec 26, 2018 04:25 AM
muskox3437
19
Oct 13, 2016 09:52 AM
Lubino Do Rego
Mar 17, 2016 08:33 AM
Cadillac
General Tech Help
Sep 23, 2014 12:39 PM
