Battery not charging warning, gearbox error
Old Feb 25, 2020 | 11:07 AM
Jssaab's Avatar
Default Battery not charging warning, gearbox error
Got a blink of battery not charging warning that quickly disappeared then the gearbox fault followed.I Read a bunch of posts and am thinking slipping serp belt,
Oddly I just serviced the transmission (of course) but think that error seems to come on with battery and charging system problems
i think I will take a look at the transmission fill level anyway. I looked at the belt, does not look glassy or cracked but I had thought I smelled a rubber burning smell over the weekend. I will check for noises up front too.
Anyone else change out the serp belt and pulleys? Any DIY ?
Old Feb 25, 2020 | 12:38 PM
Cee Jay's Avatar
Did you upgrade your XF to an XK? You MAY be in the wrong forum.
Anyway, I'd figure that the Not Charging caused a low battery condition which caused an erroneous Gearbox fault.
Old Feb 25, 2020 | 02:47 PM
TXFireblade's Avatar
Upgrade!
Gary Coker
19
Jan 2, 2024 05:57 PM
ben30
Dec 14, 2018 12:59 PM
Khb1
Mar 6, 2018 03:05 AM
dodgerjames
Jun 10, 2015 07:17 AM
