BC coliovers on my JAG XKRS
Old Nov 18, 2024 | 11:32 PM
TAEUCK Goo's Avatar
Default BC coliovers on my JAG XKRS
Hi.
Driving XKR-S 2012 recently.
I've searched in this forum but found not that much information in this regard.
The reason I am intending to install this BC coilover kit to my Jag XKRS is
1. To make it look nice.
2. Experienced so uneasy feeling of the ride when I passed bumps on the road. ( my car's set up : Stock damper + H&R lowering spring)
During my search, I found some says "CATS" , what is this?
I wonder how I could delete the error code possibly appear when I install those coliovers as I think my car has EDC.
Thank you guys
Old Nov 19, 2024 | 03:29 AM
guy's Avatar
guy
Linking together the 3 threads you have going on here… your desire to keep modding the car is what is killing the handling of the car.
Moreover, “who” is doing the work? Good luck, I’m out.
Old Nov 19, 2024 | 05:42 AM
sony2000's Avatar
The car has such a stiff ride that bumps on the road send him airborne. Add a little centrifugal force and the car heads sideways. The camber seems extreme and bye bye rubber on those tires. Just a regular XK with a screwed up alignment and she will tend to handle the same as TAEUCKs car.
Unusual wear on those wide tires will send them into vibration mode at speed.
Old Nov 19, 2024 | 06:08 PM
TAEUCK Goo's Avatar
@guy,
If you think so, what do you think is the best for improvement?
Old Nov 19, 2024 | 06:11 PM
TAEUCK Goo's Avatar
Thanks for the advice,
I'll get new tires and alignment today. will see it that works.
Thank you.
Old Nov 19, 2024 | 08:36 PM
sony2000's Avatar
You said that the springs were changed. Replace them with the originals new or used.
You said Bilstein shocks are being used and most likely they are the originals.
Are the rims more than 20" in diameter? Probably you can keep them.
MarcelC66
Apr 24, 2024 03:16 AM
Crobertrod
May 9, 2022 07:14 PM
Rw99
Nov 3, 2013 01:33 PM
Quebecjag
Canada
Oct 23, 2013 05:37 PM
michael_chen217
Aug 4, 2013 10:37 AM
