Best exhaust for XKR-S?
Old Nov 11, 2024 | 06:48 PM
TAEUCK Goo's Avatar
Default Best exhaust for XKR-S?
I brought X150 XKR-S recently.
Exhaust system sounds great but the growling is a bit quite in low speed under 2,000 RPM.
I want it to be more V8.
Which do you guys think is the best way to sound more V8.
I am thinking straight pipe for removing cats under the engine or removing x-pipe to make it straight to make it a bit louder?
Sorry for my pour english but think you will get me .
Let me know guys.
Thank you.
Old Nov 12, 2024 | 02:04 AM
guy's Avatar
guy
You do realize that if you want the exhaust louder at less than 2000 rpm… the sound will be obnoxiously loud above 2000 rpm.
Yes, removing the cats will certainly make it louder. I however wouldn’t do that to mother nature. And you will need to retune the engine due to the O2 sensors will not provide valuable data to the ecm.
Removing the x-pipe will have no useful effect.
Have you disabled the active exhaust?
Old Nov 12, 2024 | 03:05 AM
TAEUCK Goo's Avatar
Thanks for the advice
"the sound will be obnoxiously loud above 2000 rpm"
this is one thing I'm worrying about.
No, I don't know how to disable active exhaust.
Can you please let me know how to do that?
As I need to change it into dynamic mode to turn it on everytime I start the car.
Old Nov 12, 2024 | 06:40 AM
guy's Avatar
guy
:-). Look at the description of the fuse box. Remove the fuse for the exhaust.
Your exhaust will be noticeably louder at the lower rpms if you do this.
Old Nov 12, 2024 | 09:51 AM
kj07xk's Avatar
Fuse 19, in the fuse panel between the rear seats, IIRC.
Old Nov 12, 2024 | 10:36 AM
guy's Avatar
guy
Didn’t like I proposed RTFM?? ;-)
Old Nov 13, 2024 | 06:42 PM
TAEUCK Goo's Avatar
I did it last night, but still not that much satisfied in RPM below 2k
Old Dec 3, 2024 | 12:48 PM
BlueXKR-S's Avatar
I do not remember how many cats XKR-S has but it if has pre-cats, you can consider removing those but keeping the main one in place.
Or, if it's just the main cat, then replace it with a high flow sports version (200 cell or so). This way no CEL but improved noise, flow, power.
Old Dec 4, 2024 | 07:50 PM
Lothar52's Avatar
https://www.rpmotorworks.co.uk
I believe you need is the back box. and it even works with the dynamic button - personally id call them and get mine the nonactive open all the time exhaust!
Jeremy07XK
Feb 13, 2024 09:18 AM
labcoatguy
Jun 10, 2021 06:40 PM
Robert Bradshaw
Aug 26, 2019 06:22 PM
Schwabe
Nov 2, 2016 06:44 AM
hdavidson
May 18, 2015 08:08 PM
