Best X-Pipe Location on 5.0 XKR
Old Jan 26, 2018 | 10:03 PM
multistrada74's Avatar
Default Best X-Pipe Location on 5.0 XKR
i'm doing the resonator delete and adding an X-pipe in tmrw am. I assume that the best place to install the X-pipe is where the 2nd resonator is (closest one to the rear axle), or is there a more affective spot in between the 2 resonators? Thanks for any input.
Old Jan 26, 2018 | 10:14 PM
Cambo's Avatar
Put it where Jaguar did.
And make sure you get the right size
Old Jan 26, 2018 | 10:55 PM
ralphwg's Avatar
Old Jan 27, 2018 | 09:55 AM
Attachment 209301
Attachment 209302
Attachment 209303
tnx cambo. yeah, that makes the most sense, and yeah....I got a 2.25" X-pipe, which is exactly what the stock pipe came in at. I also got the X that had the least gap between the pipes (all were wider apart than the stock pipes), to make it a cleaner job.
Old Jan 27, 2018 | 10:14 AM
Cee Jay's Avatar
Maybe it is a year or model difference, but my stock exhaust is all at exactly 60mm.
Old Jan 27, 2018 | 10:34 AM
that's odd, because when we get the mic around it at the exhaust shop last week, it read exactly 2.25".
Old Jan 27, 2018 | 04:07 PM
Cee Jay's Avatar
I don't know what to tell ya. Mine's never had any work done to it except the resonator delete, and I watched the whole thing. The entire system - 60mm.
Old Jan 27, 2018 | 04:46 PM
Ranchero50's Avatar
I like putting them up close to the engine as I figure hotter gases have more energy and closer is a sharper pulse to draw the exhaust from the opposite bank. I'm pretty sure Jaguar did it where they did to sound different.
Old Jan 27, 2018 | 05:48 PM
Cee Jay's Avatar
Old-timey hot rodders (like me) used to put a mist of white paint on the exhaust pipes, and where it turned the brownest was 'supposedly' the best place for an (at the time) H-pipe. Reasoning would suggest that using the old wisdom that an X-pipe would also be in that location.
Is any of this accurate? Hell, I dunno.
Old Jan 27, 2018 | 06:06 PM
Tervuren's Avatar
The ideal location is going to change based on pressure wave location and length in the exhaust system; and this is going to be variable based on exhaust velocity and pressure, which is in turn variable by engine RPM and load.
You can also run two X-pipes if you wish.
Old Jan 27, 2018 | 06:09 PM
Cambo's Avatar
Well the factory XKR-S exhaust design "works" and i'd say Jaguar had a bigger R&D budget for this than we do...
Old Jan 27, 2018 | 08:07 PM
Cee Jay's Avatar
Yep, but their R&D also decided to put brittle coolant lines underneath a supercharger.
Old Jan 28, 2018 | 12:01 PM
jagtoes's Avatar
OK so I just went out to measure my exhaust pipes. Now I have a 2012 XKR convert with the $1400 performance active exhaust option. Stock system. I measured the down pipe after the cats and it was 2.368 ". Note as it goes into the main pipes it necks down. The OD of the pipes from here into the X-pipe and back into the back box (muffler) is 2.175 ". Pipes look new yet and they are round so these measurement were as close as I could get it. Just an FYI
Old Jan 28, 2018 | 01:40 PM
Tervuren's Avatar
Thanks for the measurements!
Old Jan 28, 2018 | 08:14 PM
S-Typer's Avatar
I just had this done on Friday. I had them install it in the factory XKR-S location.
it sounds great! Not too loud at all. I used a 2.25” X-pipe.
2012 XKR.
Joe
Old Jan 28, 2018 | 08:28 PM
jagtoes's Avatar
Based on the measurements I had taken it shouldn't be a problem welding in a 2.25 OD pipe. My bet is the pipe on the cat's are 60 mm reduced down to 55 mm. So a 2.25 pipe would be about 57 mm . The gap shouldn't be a problem welding shut.
Old Jan 29, 2018 | 06:51 PM
yep, you nailed it.
Old Jan 30, 2018 | 06:38 AM
Grimreaper's Avatar
Well I had mine at the back to start with & found on overrun most of overrun noise was in headers & seamed to be not allowing gas out quick enough. So had it moved to the front & it transformed car throttle response & made note deeper & sounded amazing on overrun ! Now pops & bangs lovely on overrun. Also repiped rear silencer inside so it was the same as the XKR-S rear box. Now it’s a real Jekyll & Hyde Now in dynamic mode with Exhaust valves open !!
Old Jan 30, 2018 | 11:16 AM
Tervuren's Avatar
Jaguar's design is likely influenced by the need to still be a GT as opposed to a brutal visceral sports car. All exhausts systems for a street car are a compromise of some sort.
When it comes to OEM, production and assembly methods create costs that also factor in to that compromise. On top of that there is design time, also a cost. Spending extra on each component delays release, costing in both engineering time, and lack of production/sales with the new design.
Old Jan 30, 2018 | 11:27 AM
Ranchero50's Avatar
It's kind of funny. On my old Lincoln LS with the Jag 3.9 AJ from the factory they combined the mid pipes in the form of an X pipe under the trans by hydro forming two sheets of stainless, only they didn't connect the pipes. Further back where Cambo's pipes have the X, it had a 3/4 main diameter 'H' connector and then a pair of X100 style mufflers tucked up behind the wheel well.
When I redid that pipe I did a 2/3 port opening X pipe (like I did in my build thread) and ran the rest of the way back with 2.5" pipe and finally a pair of Pypes turbo style mufflers. That car sounds ballsy for a little 3.9 NA engine. I wanted more of an old school E type sound so I went with glass pack style mufflers at the bumper and smaller 2.25" pipe feeding them. It has a very distinct sound as well.
