Big a
Old Sep 25, 2011 | 03:25 PM
Big A's Avatar
Default Big a
My jag xk 4.2 2007 is to quiet - can i remove the 2 blocked ports on the rear silencer and have quad pipes out the rear as per xkr - help
Old Sep 25, 2011 | 03:52 PM
davewhitt's Avatar
as i understand the xk and xkr have two different set-ups .the xk has a tim valve but the xkr has a active valve which needs a vacuum pump to close it ,so if you put a xkr rear box on a xk the valves would be open all the time aka more noise
Old Sep 28, 2011 | 03:29 PM
Big A's Avatar
Default Big a
Thanks for reply but can i remove the tim valves on my existing xk
silencer and add the two pipes to give me a quad outlet look like the xkr will it be to noisy - regards
robbing
Mar 5, 2024 10:51 AM
TreVoRTasmin
Feb 23, 2021 03:13 PM
Finbarr1975
Oct 4, 2015 05:32 PM
280zx-turbo
Oct 2, 2015 02:52 AM
JagBrian
Oct 1, 2015 12:52 AM
