Bluetooth Disconnect Solution
Old Feb 21, 2014 | 07:22 PM
Tahoe Dave's Avatar
Default Bluetooth Disconnect Solution
As indicated in an earlier post, my Motorola Razr Maxx has been disconnecting, since their software update. This update is through Google and is called Kitkat, no comment on that choice. This update, I believe is also for some Samsung phones as well.
After several calls to both Verizon and Motorola, which resulted in a net zero solution, I turned to the web. I found that there were several people having this exact problem, which is resolved by disabling the Wi-Fi when your in the car.
If you are having this issue, give it a try.
Old Feb 21, 2014 | 07:56 PM
ralphwg's Avatar
I have had the same problem intermittently with my Samsung Galaxy S4 since the upgrade. My solution is to reboot the phone. Then the problem goes away for a minimum of several days up to a week or two.
Jagzzz
Aug 8, 2021 02:45 PM
mikiep
Dec 20, 2019 07:37 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
Msteiner
Audio/Visual Electronics
Sep 30, 2015 08:36 AM
