Brake pads and disks all round
Old Mar 28, 2026 | 09:57 AM
guy's Avatar
guy
Funny. I just paid ~$800 (CAD) for OE pads and rotors, installed with service on the callipers. Another ~$100 for the oil change and filter.
And I don't think that exorbitant.
Old Mar 28, 2026 | 05:17 PM
HealeyJag's Avatar
Originally Posted by David993S
Lots of options for aftermarket rotors/pads. I went with Cquence rotors and Akebono Euro premium carbon ceramic pads. Very pleased with both. For street driving the carbon ceramic pads stop just as well as OEM pads. They don't really need much heat to bite. A little less brake dust as well.
I went with Cquence as they machine the slotted/drilled rotors themselves (rotors come from Aisa as do most rotors these days). They machine the rotos for the left and right side unlike some you find.
Performance Brake Rotors | Brake Pads & More Brake Parts | Cquence.net
Here's one of my fronts installed:
Excellent:
OK..
How long did it take you, and what was the total cost?
Thank you
Old Mar 28, 2026 | 05:18 PM
HealeyJag's Avatar
both front and back???
wow
sounds cheap
u have a great place!!
Old Mar 28, 2026 | 05:37 PM
wymjym's Avatar
wow
sounds cheap
consider the exchange rate!
wj
Old Mar 29, 2026 | 07:02 AM
guy's Avatar
guy
wj
USD576.
Old Mar 30, 2026 | 09:52 AM
luv2fly's Avatar
Default Ceramic pads
Originally Posted by sony2000
What are the members feelings toward ceramic brake pads, as opposed to the semi metallic ones?
I used Zimmerman rotors and Bosch Ceramic Pads from AUTOHAUSAZ on my 09 SV8, $362.87 in 2021. Perfect. No dust. I haven't needed rotors on the 07 XKR, but put on Centric Ceramic Posi Quiet pads all round. Again, no dust.
I've used both these brand pads before and they've always provided good service and very little dust. Break them in easy and after 500 miles, I can't tell any difference in braking. Of course, I'm not doing full on instrumented testing. I've always been pleased with the results and it's generally the first job I do on a new to me car. SL500 sitting in the garage waiting on her Brembo ceramic pads. Another good brand.
Old Mar 31, 2026 | 07:15 AM
Stuart S's Avatar
Brake pads wear and there is always brake dust. It's just that ceramic pad dust is less obvious because it's tan, not black.
Old Mar 31, 2026 | 08:25 AM
  #28
David993S's Avatar
Excellent:
OK..
Thank you
I had the shop I use do it, but I'll go back and look at the invoice and let you know the labor hours and cost for parts.
Cheers.
Old Apr 1, 2026 | 02:49 PM
David993S's Avatar
Excellent:
OK..
Thank you
Sorry for the delay in getting back. Got busy with yard work.
To remover old rotors, install new and replace pads, it was about 2 hrs. for the fronts and the same for the rears. So about 1 hr. per wheel. I'm sure that also included in raising the car on the lift and removing wheels). As for price, it was nearly 2 years ago so I'm sure parts have gone up. And labor rates are going to depend on shop and location.
Old Apr 1, 2026 | 05:00 PM
  #30
HealeyJag's Avatar
4 HOURS
just what I thought
THANK YOU
Old Apr 2, 2026 | 01:49 AM
  #31
Tornado's Avatar
I just replaced the rear pads on mine last weekend and it took about an hour on one side as I bumbled around trying to remember how to do it (my Lotus brakes work different and I did all of those the week prior)and then about half an hour to do the other side. Last summer I did all new pads and rotors, and it took all day but I didn't know how to use the brake caliper tool so most of it was spent fighting the rears (which I didn't do right, leading to it frying the rear pads) and getting the old rotors off
I bought the Powerstop drilled and slotted rotors, which they didn't have fitment officially for the XKR 5.0 but they did officially have for the F-Type and are the same thing. I really liked them when I had my Corvette and they are relatively cheap. For pads I used EBC Redstuff all around, but when I changed the rear pads over the weekend I went to Yellowstuff instead to push some of the brake bias backward a bit and increase initial bite.
coxzilla97
Aug 6, 2017 09:02 AM
Tally Ho
Aug 4, 2016 05:15 PM
phaelax
Sep 22, 2012 06:55 AM
