Brembo vs ORM pads.
Old Jan 27, 2025 | 02:48 PM
badicedog's Avatar
Default Brembo vs OEM brake pads.
Good afternoon gentlemen. I have taken up the project of massively upgrading my brakes to Alcon brake package. I bought both OEM pads and Brembo pads for the massive 400 & 350 mm rotors. Does anyone have experience with using Brembo pads?? I=Thank you
Old Jan 28, 2025 | 10:25 AM
neilr's Avatar
No experience of this application but Brembo pads are usually fine. Do you have the Brembo PRIME LINE P36024 and P36024 sets for the Jaguar C2P15991 and C2P15994 items?
From what I could see on internet pictures, the Jaguar branded ones seem to be made in the UK and have an edge code FER FF, which might suggest Ferodo as the supplier. The latest Brembos (and aftermarket Ferodos) might be GF rated, so I would expect a little more cold bite. What is written on the pads you actually have? Will be interesting to hear what you find when you are done.
Old Jan 28, 2025 | 11:59 AM
clubairth1's Avatar
Community Influencer
My only complaint with Brembo pads is the massive amount of brake dust. That's why I first went to ceramic pads but now I run CF pads instead.
Old Jan 28, 2025 | 12:03 PM
guy's Avatar
guy
Well, something has to give…
Stopping power?
Wear of pad?
Wear of disk?
Another great debate continues…
Old Jan 28, 2025 | 01:34 PM
badicedog's Avatar
I do not, I am planning to priming the outer valve first then the inner one
Old Feb 8, 2025 | 01:59 PM
XKDreams's Avatar
I dint know what’s on mine…40,000 miles ‘15 XKR, but I hate the brake dust.
Old Feb 9, 2025 | 07:13 PM
Stuart S's Avatar
I just got my XKR back from my independent ASE-Certified technician who installed replacement Centric Alcon rotors and Brembo ceramic pads. I'm still bedding in the new pads, and don't have enough miles on them to say much. So far, they're quiet and the pedal feels the same as the original rotors and pads. But the Brembo ceramic pads leave light grey dust, which is much less noticeable than the black dust from the OEM pads. Hats are painted matte light grey.
(Photo taken at night with flash)
Old Feb 10, 2025 | 09:55 AM
clubairth1's Avatar
Good to hear Stuart! I did not know Brembo had a ceramic option.
When I changed mine to ceramic I felt the initial bite was less aggressive compared to stock Brembo pads. Perfectly fine just a bit different. Plus I found that light colored brake dust came off much easier than the factory black dust from the Brembo's.
XKRAU
May 16, 2022 04:24 PM
giandanielxk8
Jan 13, 2018 08:20 PM
Wrightway
General Tech Help
Jul 25, 2016 02:53 PM
likica
Jun 4, 2015 06:07 PM
reko19
Feb 18, 2011 09:34 PM
