Brief Electrical Question
Old Apr 8, 2024 | 04:00 PM
Colt23's Avatar
Default Brief Electrical Question
Hi all,
whilst it well understood that a bad battery and in particular a reading below 12.6 causes a large majority of the electrical issues in Jaguars, why is it that some is not many of these electrical faults appear whilst the car is being driven and when the electrical supply is being provided by the alternator (providing it is working properly) at around 14.3 volts. Is it perhaps the case that the electrical supply to many of the modules is supplied via the battery and as opposed to directly from the alternator whilst the car is running. In this instant, would a battery that is not necessarily not able to hold a higher enough voltage still not be able to receive (from the alternator) and pass on the correct voltage to the various modules.
Regards.
XKR 2007.
Old Apr 8, 2024 | 05:34 PM
Cee Jay's Avatar
You'd think so, but also volts are not amps. Plus, with a bad battery, the alternator attempts to charge that battery. That's where a lot of alternator output goes, leaving less to power the car.
Don Holtz
XJ40 ( XJ81 )
21
Dec 7, 2019 01:45 AM
nurquhar
Oct 6, 2018 09:36 AM
gunnerman
XJ40 ( XJ81 )
Feb 28, 2018 12:04 AM
Stevie b
Aug 15, 2016 06:29 PM
yonhottscott
May 5, 2009 04:35 PM
