Can you help me name that part ?
Hi all,
I am looking to buy these holders, which are missing from my used Jag :
They are used to hold the bottom cover of the passenger-seat's dashboard. There are three of those which attach the plastic / fabric bottom-cover to its place.
Without the three of those, it looks like that :
If you can help me identify the name / part number of those, that will be great..
Thank you!
Thank you!
Most likely you will be able to read some lettering or numbering on the part.
Go to:
https://www.jaguarforums.com/forum/x...solved-107977/
ClipsAndFasteners.com - Automotive Retainers,Clips and Fasteners
Keep in mind that many of the fasteners used are supplies from FOMOCO, or Ford Motor. Allot of the fasteners are cross used amoung different brands from Ford, especially Lincoln.
Search through the website and you might be able to find the replacement.
For those owners who have lost fasteners from under the hood for the palstic covers have had good luck finding replacements through clips and fasteners website, including myself.
This is your best source before going through a dealership parts department. Cost thru the parts dept is about 15x the price on the clips website.
Good luck and hope this info helps.
Go to:
Thanks Richard. You are right I did find numbering on the part : 709688.
A search in ClipsandFasteers.com didnt bring up any results though, nor did a google search
I will do some more searching on the ClipsandFasteers.com to visually recognize it. It seems i might need a similar but not identical part ?
Thanks again for the guidance!
Judging by the parts guide I think you are after C2C28479 - insulation pad lower fascia fixing
You can see a picture here:
JAGUAR CLIP C2C28479 in Body Closures And Sealing
Scott B
Oct 24, 2015 01:29 PM
