Car is dead !!!
Old Sep 10, 2021 | 09:08 PM
jons's Avatar
sounds like a busted relay? you could remove them one at a time, apply power, see if the clicking stops when a particular one is out.
Old Sep 10, 2021 | 09:16 PM
Sean W's Avatar
Well hang on before you tow. I'm not sure what 98% charged actually means. I don't think in those terms but a fully charged battery is 12.6 volts resting. 98% of that is 12.34 volts which equals a dead battery. What is the actual voltage showing at the battery terminals? Any auto parts store will load test the battery for you at no cost.
Old Sep 10, 2021 | 09:19 PM
Sean W's Avatar
I read that you have a new battery in your first post but humor me and read out the voltage at the terminals please.
Old Sep 11, 2021 | 02:07 PM
Addicted2boost's Avatar
We have had at least two, if not three X150’s towed to the shop in the past 3 or so years because of this power stud (primarily on the underside of the car) being corroded. They also had the same issue as you did, good battery voltage but still dead. I highly recommend cleaning and tightening the nuts and cables on the top and bottom side of this power stud.
Old Sep 11, 2021 | 03:08 PM
jahummer's Avatar
I had something similar happen, ended up being a faulty ground.
khsjsilver
Jul 27, 2021 09:02 AM
LoneAspen
Mar 26, 2019 11:25 AM
Loxmth
Dec 9, 2018 09:29 AM
newjagnc
Jun 14, 2018 06:34 PM
SV8Predator
Apr 12, 2009 04:26 PM
