Changing the air filter on a 2008 XK
Old Oct 7, 2012 | 12:16 PM
daxter1987's Avatar
Default Changing the air filter on a 2008 XK
Changing the air filter on this car is a little more complicated than it should be... having to remove the wheel and all... I did it, took pics and wrote the procedure if anybody is curious on how to check or change it... here is the link...
Jaguar HELP!: How to change the air filter on your Jaguar XK 2008
PLS faq!
Old Oct 7, 2012 | 01:37 PM
britannia's Avatar
just a minor comment! I always remove wheel nuts after jacking, not before, using an impact wrench..................otherwise Thanks for pictures............
Cheers, Adrian
Old Oct 8, 2012 | 08:46 AM
rscultho's Avatar
PLS faq!
Are the air filters iin the same place on 2010+ models?
TIA
Old Oct 8, 2012 | 09:25 AM
daxter1987's Avatar
2010 with the 5.0 Liter engine I think it has two air filters and I honestly only read about them in training manuals. for what i see in pics yes, they are in the same place but there are two, one in each wheel Now wether there is more screws, or less, or clips, i won't know until they go out of warranty and they start coming to my shop.
good luck.
Old Oct 8, 2012 | 09:27 AM
daxter1987's Avatar
Cheers, Adrian
I said crack when the car is down and set it up and remove the lugs when the wheel is up, they are harder if not impossible to crack when the wheel is up unless somebody is stepping on the brake. Mechanics like you and me use an impact wrench I agree.
Old Jan 28, 2013 | 05:37 PM
White Bear's Avatar
Mods,
Shouldn't this be a sticky?
Regards,
White Bear.
Old Jan 31, 2013 | 07:14 AM
Chaos236's Avatar
Pita
Old May 6, 2015 | 07:34 AM
chas_c's Avatar
Does anyone have the information that was in the link?
The link is old and does not exist anymore
Thanks in advance
Chas
Old May 6, 2015 | 08:32 AM
kj07xk's Avatar
Just tried the link, worked for me.
Old May 6, 2015 | 08:54 AM
RedRider48's Avatar
Ditto, on the "Nut Cracking" sequence. I too, break the strangle hold while the weight is on the ground. This is true for my E-Type's knob-offs, as well.
Once the nuts are slightly loose, I remove with a gun.
Thanks for the write_up!
BTW, what torque did you use for tightening?
Old May 6, 2015 | 09:32 PM
chas_c's Avatar
Thanks, I tried the link again and it WORKED !!
Thanks again
Chas
Old May 8, 2015 | 12:04 PM
Fugowitz's Avatar
Hi, just to share on how my machnic did the airfilter change on my xk recently. He turned the steering to the far-end so that the wheels toed in, and exposing the inner wheel-arch. He then unscrewed the wheel-arch to reach the air fillter box (to change the filter) without undoing the wheels. All done under 3 minutes. Lazy but efficient bugger.
Old May 8, 2015 | 12:25 PM
RedRider48's Avatar
bugger.
Hi, by "far end" meaning extreme right or left?
Old May 9, 2015 | 04:18 AM
Fugowitz's Avatar
Hi Redrider,
My ride is a right-hand drive, and the airfilter is located on the left-hand passenger side. So, the steering was turned to the right extreme end. The left wheel would toed-inwards right, leaving sufficient room to undo the wheel-arch screws. The wheel-arch is made of flexible material which could be bend/ contorted slightly to make the airfilter change. Hope that helps.
Old May 9, 2015 | 08:38 AM
RedRider48's Avatar
Hi Redrider,
Thanks for clarifying...
Happy Motoring.....
Old May 9, 2015 | 01:47 PM
chas_c's Avatar
I'm going to try this method.
I just did the left side and took nearly two hours! A lot of the time was jacking the car up safely.
Will try the right side like this and report
Old May 9, 2015 | 03:48 PM
jehart49's Avatar
I believe the 07 and 08's only have one filter.
Old May 9, 2015 | 06:50 PM
chas_c's Avatar
wheel on full right lock - LHD vehicle left wheel
wheel on full left lock - LHD vehicle - left wheel
Hi Redrider,
I could not resist the temptation.
My car is a Left Hand Drive 2009 XKR so may be different but there seems to be more room if the steering wheel is turned OUT, meaning to access the left hand side filter, turn steering wheel to the left.
Chas
Old May 12, 2015 | 11:00 AM
Fugowitz's Avatar
Hi Chas,
The first picture with the wheel at full right lock is it (if the airfilter is located at that side.) That little patch of space (as shown in the pic) is where the airfilter box is located and could be pulled out (like a cartridge) once the screws are undone. The space available is just about enough to do the airfilter change. But i gusss those folks with burly hands might find it abit more challenging.
Old Feb 27, 2016 | 02:20 PM
jehart49's Avatar
I just changed the filter on my 07. I have 20" wheels and turning the wheel right didn't provide enough clearance to remove the filter. The job, including jacking the car and removing the wheel, was about 45 minutes.
Jag didn't give a lot of thought to filter changes when they designed this car. The cabin filter is a PITA too.
