Computer codes
Old Aug 18, 2019 | 10:44 PM
jerome41441's Avatar
Default Computer codes
I found a YouTube video on jaguar secret computer access. You select Navigation, then hold the colored bar above the navigation menus. Hold it about 10_20 seconds. Then a keyboard will pop up The codes I got so far are as follows:
660 Diagnostics menu
662- GPS
661- Systems Check
944 Service
Does anyone have any other codes and does anyone know how to reset the service light?
Old Aug 19, 2019 | 04:09 AM
u102768's Avatar
To re-set the service interval indicator, the following process switch presses must each be carried out within 3 seconds:
  • With the vehicle in power mode 0, (ignition off) press and hold the rear fog lamp switch
  • Allow the vehicle to enter power mode 6 (Press the start button without a foot on the brake)
  • Immediately release the rear fog lamp switch
  • Press and hold the trip computer cycle switch
  • Press and hold the rear fog lamp switch
  • Continue to hold the trip computer and rear fog lamp switches
  • If the process has been successful, the message center will display 'RESETTING SERVICE MODE' and then display 'SERVICE MODE RESET' after 10 seconds
  • Release both switches and return the vehicle ignition to off, power mode 0.
Rahtok
Aug 1, 2020 04:10 PM
wardwe64
Aug 6, 2018 01:25 PM
raulchamy
XF (X260)
Jan 17, 2018 06:19 PM
TMack
Sep 9, 2014 04:22 PM
10 XF Premium
Apr 9, 2013 06:44 PM
