Service Required
Old Apr 5, 2012 | 12:59 PM
Rahtok's Avatar
Default Service Required (How to reset Service Reminder for XK/XKR)
OK, so this message started showing up earlier this week, but I can't seem to figure out why. I don't have any CELs, and it's only been about 3000 miles since I had the oil changed. How can I tell what this message is about shy of spending half a day dealing with an in person service visit? Thoughts anyone?
It just says "service required" in yellow, then is replaced by the clock and never shows back up again until the next start cycle. No other messages in the main screen area, and I can't cycle back to the message. Has this message always been there and I've been too daft to notice it?
2010 XKR Startup Screen - YouTube
Popular Reply
Apr 9, 2012, 06:30 PM
Rahtok's Avatar
Rahtok
Thanks to Brutal for clarifying/confirming and this other website here: (http://www.jaghelp.com/2012/03/reset...jaguar-xf.html), this is the reset procedure for this, btw.
  1. Press and hold the rear lamp switch.
  2. Press the start button without applying the foot brake.
  3. Release the rear fog lamp switch.
  4. Press and hold the trip computer cycle switch.
  5. Press and hold the rear fog lamp switch.
  6. Continue to hold the trip computer and rear fog lamp switches.
  7. The message center should display "resetting service mode" and then "service mode reset"
  8. Release the trip computer and the fog lamp switches and turn the ignition off.
It's REALLY finicky for timing, but it does, in fact work. And the 'resetting service mode' indicator will come on right after pressing the foglamp button the second time -- so you know if you've got the sequence right pretty quickly. It takes another 15 seconds or so of holding both buttons to finish the reset, but if you watch the LCD it says things that make sense.
Old Apr 5, 2012 | 01:29 PM
Brutal's Avatar
Oops, looks like someone forgot to reset the service reminder at the oil change
Old Apr 5, 2012 | 06:15 PM
Rahtok's Avatar
Rolls eyes. I was wondering that! lol -- thanks Brutal. I guess I do need to drop by. Unless there's a way to do it myself... <hopeful eyebrow raise>
Old Apr 9, 2012 | 06:30 PM
Rahtok's Avatar
Old Apr 10, 2012 | 10:53 AM
axr6's Avatar
The link you provided is for the XF. One of the comments in that link says that it will NOT work on the XK/XKR. So, you are confirming that it DOES work the same on the XK/XKR?
Thanks for the post,
Albert
Old Apr 10, 2012 | 12:48 PM
Rahtok's Avatar
Yes, it DOES work for the XK/XKR. I did it yesterday.
Old Apr 10, 2012 | 12:54 PM
Brutal's Avatar
The only one that it wont work for is the new xj
Old Mar 26, 2013 | 01:45 PM
Rique's Avatar
Its a bitch to get the timing right but once you get it it will work as described. Thanks Mr. Techman.
Old Mar 26, 2013 | 02:12 PM
Brutal's Avatar
The biggest issue is trying to "think" you have to be fast. Think of a slow tick tock cadence and it works everytime
Old Aug 7, 2013 | 01:45 PM
Geoff Rouse's Avatar
I've tried the reset above a dozen times on my 2010 XF but no joy. I'm unclear whether the ignition should be on before pressing and holding the fog light switch (in which case pressing the start button will turn the ignition off) or whether the ignition should be off before pressing the fog lamp switch for the first time (in which case pressing the start button will turn the ignition on) I've seen both instructions on the internet but neither seems to work. Any advise on timing (presses 1 second apart, 2 seconds apart etc)?
Old Aug 8, 2013 | 06:47 PM
Rahtok's Avatar
Car should be off to start. Foglight, THEN start (but no foot brake). It took me quite a few tries. The steps I listed above is exactly what I did to reset mine.
Old Aug 9, 2013 | 05:22 AM
jagxk2008's Avatar
so we did well to clear this message and i will bring my car in for service at 13-14 k instead of 16. but definatly not at 10k km.
Old Aug 18, 2014 | 07:16 PM
Muddydog's Avatar
Awesome! Worked like a charm. Thanks guys. I knew this would come in handy someday!
Old May 1, 2016 | 12:36 PM
Slee_Stack's Avatar
Took me about 15 tries for it to work, but finally did.
Old Jul 27, 2016 | 02:58 PM
jima's Avatar
+1 works fine for a 2010 XKR. Got it on second go. Easier than the instructions suggest once you got the rhythm and keep foot OFF the brake pedal.
Fog light in...
Hit Start
Fog light out
Trip AND fog light in...
Wait for message...
Done...
Thanks to all. I just had a service, Stratstone clearly forgot to reset. They would have done it FOC I am sure but this saved me a round-trip, time plus fuel.
James
Old Oct 26, 2016 | 03:26 PM
WarrenFRenneisen's Avatar
Default Reset Service
Will the above sequence work for me if I change the oil in my 2015 6 cylinder F-Type Coupe?
Old Oct 26, 2016 | 05:09 PM
Sean W's Avatar
Warren, this is the XK/ XKR 150 forum but it will cost you nothing to try.
Old Aug 1, 2020 | 12:30 PM
AJagXF's Avatar
Default It's fast timing too get it right...
Hold rear fog light button, then quickly:
- press start
less than 1 second between steps
- release start and fog light at the same time
- now press trip and fog light at the same time....and hold
- Now keep holding them both 10-15 seconds until message says it's reset is done
Originally Posted by Rahtok
Thanks to Brutal for clarifying/confirming and this other website here: (jaghelp.com: Resetting the service light on a Jaguar XF), this is the reset procedure for this, btw.
Old Aug 1, 2020 | 04:10 PM
George05's Avatar
I used the jlr icarsoft v11 on my friend steves car , but all it said was press on rear fog light switch and stalk as others have posted . got their in the end
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
mrsimpson
Sep 15, 2015 01:10 PM
teacoff
Sep 10, 2015 08:25 AM
1964Daimler
Sep 9, 2015 04:50 PM
