Coolant leak. Valley hose/pipe issue effecting our cars much?
Old Dec 4, 2019 | 02:12 PM
AlexJag's Avatar
Sponsor
Default Coolant leak. Valley hose/pipe issue effecting our cars much?
Hey guys! The reason I'm asking, for the first time ever I smelled some coolant at the stoplight and decided to check the level, I was low about 10 oz.
I tried to visually find a source of the leak but nowhere to be found. Started googling and came up with this Valley hose issue that's affecting 4.2 and I believe 5.0 cars but I haven't seen too many posts about it in x150 XKR section.
How prevalent is this issue with our cars?
Since I can't find the source of a leak and it's obviously have leaked out somewhere this is the only thing I'm suspecting.
My car 2008 XKR 93k miles
Expansion tank was replaced 2 years ago
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Dec 4, 2019 | 03:31 PM
Sean W's Avatar
I suspect it's because there are far fewer X150's in production than S-Type's and X350's, but the same engine and same set up (on the 4.2 anyway). And prolly more than half of ours are garage queens:-) The most common place found is coming off the transmission tunnel passenger side if memory serves. Adding a dye pack and pressure check should lead you to it.
Old Dec 4, 2019 | 04:39 PM
gkubrak's Avatar
As mentioned above, if you suspect the valley hoses, they would leak coolant down the transmission and you would be able to see it from under the car. Not sure if it would pool up in the valley itself but that should be visible from the top.
EDIT:
I have a mystery coolant leak that I believed I solved. Will post later tonight since I have pics and it doesn't have anything to do with the valley hoses.
Old Dec 4, 2019 | 06:19 PM
jahummer's Avatar
Probably jinxing myself but when mine goes I’ll take the opportunity to do a port, polish and rebuild.
Old Dec 4, 2019 | 07:27 PM
AlexJag's Avatar
Sponsor
EDIT:
please post back with what you found
__________________
Old Dec 4, 2019 | 07:29 PM
AlexJag's Avatar
Sponsor
I was thinking along the same lines, but more on the 10% pulley. Not sure about the port , haven't seen a single proof that it adds any power on gen 5 m112
__________________
Old Dec 4, 2019 | 11:05 PM
gkubrak's Avatar
So theres a small leak from this hose. Which I clamped and put some RTV on. Looks like its still leaking a bit though. Guess I'll have to replace that hose at some point.
As I had the bumper off, I noticed a nice gooey drip from the front of the engine. Can't see anything from the top or the water pump.
Is this from the oil cooler lines? What are we looking at here in terms of repair?
Old Dec 5, 2019 | 12:58 PM
gkubrak's Avatar
Any advise on this ^^^
Old Dec 5, 2019 | 01:59 PM
Sean W's Avatar
Any way you could run a scope up there?
Old Dec 6, 2019 | 03:04 PM
AlexJag's Avatar
Sponsor
So driven the car for last few days, so far no loss of coolant at all. I slightly overfilled it and it's still at exact spot. Scratching my head here
__________________
Old Dec 6, 2019 | 03:29 PM
gkubrak's Avatar
Sounds like your issue has been resolved!
Either way I think I will start my own thread to document my issue.
I don't believe we have the same leak lol.
Old Dec 6, 2019 | 05:25 PM
AlexJag's Avatar
Sponsor
Don't think leaks just resolve themselves . It has leaked out and I smelled it for sure . Just that it hasn't leaked out in a few days just makes it harder to find. If your still experiencing a leak and you found the hoses just replace the hoses as they will most likely leak more later due to age..
__________________
Leo032
Feb 8, 2018 07:08 PM
platinummaker
Jul 11, 2015 10:12 AM
Paolo78
Sep 8, 2014 04:15 AM
YYC guy
Jun 27, 2014 07:47 AM
sempire
Nov 18, 2010 09:20 AM
