Correct Bush for Shock Asborber
Old Feb 22, 2023 | 10:59 PM
Colt23's Avatar
Default Correct Bush for Shock Asborber
HI,
having failed its WOF(annual safety check) on the lower bush on the rear shock absorber (amounst other items) I've purchase the part from a local suspension company after they crossed reference it against the Jag part number. As per the attached photo they is an "off-set" on each end against the centre rubber and barrel. In the absence of any prior experience of these type of parts and before I attempt to fit the same could someone advise is this is indeed the correct part, and possible the reason for the shape of this bush.
Also I Thank You to the forum (having read pass post from a couple of years ago) who correctly led to an easy and inexpensive fix on another failed item in so far as the indication and hazard lights on the right front not flashing. It was indeed just a faulty earthing point, nut came off in my hand. New drilled hole in the chasis, wire brush and new bolt, and all working like new.
Regards,
Colt.
Old Feb 22, 2023 | 11:44 PM
McJag222's Avatar
What's the relevant part numbers?
Old Feb 22, 2023 | 11:53 PM
McJag222's Avatar
Old Feb 23, 2023 | 03:01 AM
Colt23's Avatar
Hi McJag22,
part number appears to be C2D4013.
Regards,
Colin.
Old Feb 23, 2023 | 10:05 AM
Sean W's Avatar
Originally Posted by Colt23
Hi McJag22,
Regards,
Colin.
It's the correct part #
Old Feb 23, 2023 | 10:36 AM
McJag222's Avatar
Hi McJag22,
Regards,
Colin.
Doesn't fit according to the parts look up:
You can check here put in your year and model and part #
https://parts.jaguarcary.com/oem-par...ulator-c2d4013
Old Feb 23, 2023 | 03:46 PM
McJag222's Avatar
Some confusion with that part # according to Barrett's C2D4013 is the right part:
https://www.sngbarratt.com/English(U...SPENSION(14714)
Old Feb 24, 2023 | 04:52 AM
JonWat's Avatar
Hi McJag22,
Regards,
Colin.
It would be really, really helpful if you told us the year of manufacture & the model or maybe even update your signature for future reference.
Old Feb 27, 2023 | 10:08 PM
Colt23's Avatar
Thanks to those who replied to my post.
It would appear that the confusion surrounding whether this is the right part is driven partly from the part being used over a number of different models and the part being superseded a number of times. A little bit cheeky have not purchased the part from the local dealership, but I told it into there parts department and they have confirmed that it is indeed the correct part. Also and rather embarrassingly the "offset" on the inner part of the bush that I previously questioned is nothing more than the normal play or movement in the design. I carefully placed it in a vice, stuck a bolt through the center and was with a little force able to move the inner shell. As per the picture below it now looks like all the diagrams on the internet!!
olivermarks
Jul 20, 2022 02:08 PM
1997Sovereign
Feb 29, 2016 09:28 PM
mikesmith2
May 23, 2014 06:51 AM
James Lewis
Mar 20, 2013 06:10 PM
guncharmer
Feb 11, 2012 10:52 AM
