Crackling/hissing noise from engine bay
Hello All,
Recently noticed a crackling/hissing noise from the engine bay on my 2010 XKR.
Car is operating ok , no warning lights on the dash etc
Nothing visible in engine bay to suggest leak of any kknd or torn cables
I have attached a couple of mp3 files recording the noise.
Wondered if anyone has come across this issue ?
Many thanks
Many thanks
Sounds like either a rubbing belt or bad accessory pulley bearings. I'd first check the idler pulley, that's the easiest thing to check. BUT, since the belt would be loose at that point anyway, the other pulleys could be rotated. All should be buttery smooth and nearly silent. It sounds a bit too tinny for water pump problems.
Many thanks for the reply. Weird part is that the crackling noise occurs when engine is off. Can hear it as i approach the car
I’m not getting much out of your clips.
Could be your ‘sounder’ going bad, if so, it’ll drain your battery.
Search this forum for ‘Geiger counter’, as that’s what others have reported what it sounds like.
