Cruise not available
Old Jul 22, 2020 | 02:36 PM
sov211's Avatar
Originally Posted by George05
Thanks guys , have just advised Steve to buy a new battery , I took a reading a few mins ago and it was 12.3 v had been on full charge over nite last nite for 12 hrs and battery was only 3 years old he told me , Previous owner had it installed and he had the receipt in service records documents from last owner was £325 from a jaguar dealer . Also advised him on the map , saying if the new battery don't remove warning to go back to them , will update this thread of outcomes
IMPORTANT: New batteries are almost NEVER fully charged - and these cars need batteries that put out full voltage - so a new battery, before installation or immediately after, must be brought to full charge. If it is not ,the car may still show faults in various systems (and the real fault will be the under-cahrged new battery!).
Old Jul 22, 2020 | 02:43 PM
tberg's Avatar
My Cruise Control Not Available Amber warning light disappears a couple of seconds after start up, it doesn't stay on the screen. Does your friend's warning stay on permanently?
Old Jul 22, 2020 | 02:58 PM
George05's Avatar
Thanks, yes have advised to charge before fitting will let you guys know out come. Thanks again for all your help
Old Jul 23, 2020 | 03:46 PM
Stamford's Avatar
In the Xk8/XKR the brake light switch also controls the cruise. Are you sure your brake lights are working?
Old Jul 23, 2020 | 04:17 PM
George05's Avatar
No the cruise not available only pops up for a second then gone
Old Jul 23, 2020 | 04:22 PM
George05's Avatar
Not my car a guy across from us , i never thought to try the brake lights to late at nite to go to his door now , he has ordered a new battery , Will speak to him over the weekend . i had read some were that the brake pedal switch could be the problem but that was on xtypes
Old Jul 23, 2020 | 04:54 PM
Wingrider's Avatar
The code about the cruse not available stays away after running for a couple min's, when restarted, when my battery was bad.
Old Jul 23, 2020 | 05:12 PM
  #28
George05's Avatar
Me thinks it is the tune he had done via the OBD port and not the ECU
Old Jul 24, 2020 | 07:01 AM
Stamford's Avatar
I replaced my brake light switch a few years ago when I had no brake lights, even though my cruise was still working. Now I have the opposite problem: my brake lights work but my cruise does not. I haven't rushed to re-replace the switch as it is a PITA to do.
Old Jul 24, 2020 | 09:51 AM
  #30
George05's Avatar
Steve informed me new battery has arrived and has took a reading of 12.5v from it , have told him to put on the charger I left him ( a full charger type ) I will pop over to his once home
Old Jul 26, 2020 | 02:19 PM
  #31
George05's Avatar
Well new battery arrived on Friday gave a reading of 12.5v so it was put on charge over weekend , took a reading of 14.2 before taking it of charger , Then we took out the old battery starting with negative and positive cables then removed all the floor matting boot spare wheel liner , And then the bar that goes across and battery clamp , got old battery out it read 12.3v its now on full charge and will be kept for a spare , Installed the new battery then did clamps etc , Then held both leads together for 30 secs, Took us over half an hour to remove and install so could say the ECU has had a hard reset then put on negative and positive leads , started car message on screen asked to put foot on brake and apply hand brake . Radio did not need resetting nor did windows all this took over half an hour , on starting car , Cruise not aviliable came back on , Switched car on and off 3 times still the same , Started car then I went with him for a run , car drove good no faults on screen , once home car ignition switched off , with door open ignition was then put on without starting car , warning light never came on , started car then it comes on as before for split second . Forgot to say I had removed a few fuses and replaced them before taking old battery out. Replaced fuse for Obd port, cruise control, brake fuse . Them fuses in passenger foot well are a PITA to get to . So out come is he will ither have to live with the tune or get them that put it on to remove it , new battery bought from Tanya batteries uk saving £42 , new battery is a Yuasa 5000 silver guaranteed for 5 year .
Old Jul 26, 2020 | 02:32 PM
  #32
George05's Avatar
Forgot to add , I checked the fuses I removed and all looked ok but replaced them , only thing I can think of is now to replace the cruise module but have told Steve he would probably be better getting the car hooked up to the sdd software first
Old Jul 26, 2020 | 03:29 PM
  #33
George05's Avatar
Steves happy he had been getting problems with his drivers seat lumber function was not working , I replaced fuse 30 and 32 located in passenger foot well all working now
Old Aug 18, 2020 | 12:34 PM
  #34
George05's Avatar
Resolved. By the look of it . Initially I had hooked up my icarsoft v2 to steves car , was picking up loads of codes inc , No comms to Ecu and more , cut long story , I replaced the battery in his car with a new one he had bought on my recommendation, but it would not reg to the Bms , But car drove good, The cruise not available message came up due to a bad map and the lost coms to Ecu , mostly due to a bad Indy garage he had used for servicing ,Seems they were not clearing codes and putting bugs on the car via their diagnostic s, a few days at a good auto electric dude fixed all, That was last week car has been good since
Stephen Kuhn
Sep 22, 2019 09:59 PM
Mediawiz
Aug 15, 2019 03:40 PM
WinterJag
Jun 18, 2015 08:16 PM
hawesr14
Dec 26, 2014 05:02 AM
