Curious about alternator
Old Jan 28, 2016 | 09:12 PM
jagtoes's Avatar
Default Curious about alternator
Does anyone know if the late model 5.0L engines us an ADP (alternator decoupler pulley) type system on the alternator. Just wonder if Jaguar went to this type of pulley and if so which design are they using . Is it the OAD or the OAP type. Just curious.
Old Jan 29, 2016 | 08:01 AM
SeanU's Avatar
There is a description of the belt system in here :
http://www.jagrepair.com/images/Trai...%204-15-09.pdf
Not sure if it answers your question though.
Old Jan 29, 2016 | 11:03 AM
jagtoes's Avatar
Thanks but no info about the alternator
Old Jan 30, 2016 | 06:21 AM
m20nuts's Avatar
Having just changed mine, the pulley has some sort of drag clutch internal to itself.
If you spin it then stop it quick, the armature does continue to move for a fraction more.
Old Jan 30, 2016 | 07:22 AM
jagtoes's Avatar
OK thanks so now it will be interesting to find out what type. There are 2 different types as I understand with one that is locked in one direction and free wheeling in the other direct and there is one that has a spring in it that dampens the free wheeling . If these fail the result could prevent the alternator from charging or it will put more load on your alternator bearings during overrun or shutdown.
Old Jan 30, 2016 | 07:49 AM
m20nuts's Avatar
It never locks in etheir direction so it must be the drag Spring type.
You can feel it slip when you rotate the armature in etheir direction.
Addicted2boost
Jan 24, 2016 05:35 PM
robert moon
Jan 19, 2016 08:52 PM
Rajamogan
Jan 19, 2016 11:00 AM
philwarner
Jan 18, 2016 11:42 AM
BlkCat
Jan 13, 2016 04:59 PM
