Custom exhaust, 200 cell cats and... p2098/p2097 - too lean fuel trim post cats
Old Aug 7, 2021 | 08:28 AM
tmich's Avatar
Default Custom exhaust, 200 cell cats and... p2098/p2096 - too lean fuel trim post cats
Hi,
After 500+ km (~1000 miles) of my custom exhaust usage I received codes on too lean fuel trims post cats (Post Catalyst Fuel Trim System Too Lean Bank 1 and Bank 2).
O2 sensors are in emulators (not straight bolt into a cat, but a 90 degrees bend). Cats are 200 cells magnaflows.
Car has a tuned soft - not yet adjusted post an exhaust swap.
As it was working well for quite a long distance, thought it will be fine for ages. But unfortunately it is not.
Workshop manual suggest air leaks between o2 sensors (before a cat) - not too possible; Or dead o2 sensor - which would be weird to get both dead at the same time (both bank 1 and bank 2 errors showed up at the same time).
AFRs are good - rather too rich (below 14.7 all the time).
I will try with replacing both o2 sensors. But happy to hear your suggestions on these two specific codes (p2096 and p2098). Maybe someone with 200 cells catalytic converters had similar problems...
Thanks!
Old Aug 7, 2021 | 08:31 AM
tmich's Avatar
Error in a title - should be p2096 and p2098 - it is about too lean fuel trim.
Old Aug 7, 2021 | 08:34 AM
Cambo's Avatar
Originally Posted by tmich
Hi,
Thanks!
The answer is right there.
Old Aug 7, 2021 | 08:47 AM
tmich's Avatar
Well, sounds super logic (that was also my first thought). So should I go straight to a cat with an o2 sensor, given 200 cell cats? Won't it cause too rich fuel trim error?
Old Aug 7, 2021 | 09:12 PM
Cambo's Avatar
Put the O2 sensors in the exhaust stream properly, the downstream sensors are used for fuel trims.
You will only get faults P0420/P0430 for catalyst efficiency, which any half-decent tuner can disable.
That's about all there is to it.
Wight8
Jul 25, 2020 05:35 AM
LoopbackZero
Jan 13, 2016 02:04 PM
ZenFly
Dec 17, 2015 04:46 PM
Gus
May 9, 2011 01:14 PM
gbdiver
May 26, 2010 05:25 PM
