Cylinder compression test - 5.0 S/C
Old Jun 23, 2021 | 03:07 AM
tmich's Avatar
Default Cylinder compression test - 5.0 S/C
Hi,
Got my spark plugs replaced so asked to check a compression, having this opportunity. Results are equal at each and every cylinder - 110psi.
Looks low comparing to NA engines, but 8 results being equal looks promising.
What are your thoughts? Bear in mind XKR - 5.0 supercharged 62k miles on a clock...
Old Jun 23, 2021 | 03:18 AM
OzXFR's Avatar
A forced induction engine will almost always have a lower compression ratio than the equivalent NA version coz the greater volume of fuel/air mix more than compensates for the lower compression. Dunno about diesels though I guess it would be the same.
Old Jun 23, 2021 | 06:39 AM
guy's Avatar
guy
road test time
Old Jun 23, 2021 | 06:51 AM
tmich's Avatar
Originally Posted by guy
road test time
Car runs very well (almost 600bhp on a dyno after tune). But did not run another 5.0 s/c, so lack of A/B to comparison.
Old Jun 23, 2021 | 08:23 AM
gkubrak's Avatar
If you look at the procedure in the repair manual, you'll note there is no 'nominal' pressure. This is due to the variation in testing equipment - specifically the length/diameter of the air hose being used, among other variables.
From the manual: "The indicated compression pressures are considered within specification if the lowest reading cylinder is within 75% of the highest reading."
By that definition, your engine is solid.
I guess the only real way to know is to use the same tester on another 5.0 S/C Jag engine and compare.
This might help:
http://www.healey6.com/Technical/Nom...20pressure.pdf
Old Jun 23, 2021 | 09:51 AM
No Quarter's Avatar
All within 10%=all is good
Old Jun 23, 2021 | 10:06 AM
tmich's Avatar
In my case they are within 0-5% range (as gauge is not super accurate) - but all of them had equal results.
So all in all - I take it as a healthy engine, no signs of extensive usage so far.
The Moneypit
May 2, 2018 09:37 AM
avt007
Apr 14, 2014 04:43 PM
Mish_Mish
Jun 28, 2013 08:08 AM
AristoCat
May 3, 2012 02:10 PM
97xkeconv
Sep 10, 2011 02:11 PM
