Dash Cam in XKR
Old Apr 3, 2014 | 11:21 AM
richzak's Avatar
Default Dash Cam in XKR
I want to add a dash cam in my 2009 XKR.....
I want the dash cam to turn on when the ignition switch is turn on .....and off when the ignition swith is turned off.
Some cars you can simply put the camera plug into a 12v auxilary and it works this way.
I don't want to hard wire.
Any thoughts?
Old Apr 3, 2014 | 11:38 AM
ndy.boyd's Avatar
Richard, do you intend to buy a new camera or use the one in your bedroom?
Old Apr 3, 2014 | 11:41 AM
richzak's Avatar
I will keep the one in the bedroom, but buy another for the XKR.
You're funny Syd.
Old Apr 3, 2014 | 11:46 AM
amcdonal86's Avatar
The cigarette lighter near the shifter turns off when the ignition is off and you lock the doors (there may also be a time component, I'm not sure). Is that good enough, or does it literally need to go off when the ignition is off?
I thought about doing something like that myself, but I don't want to attempt it until I have a battery maintainer!
Old Apr 3, 2014 | 12:10 PM
M6XKR's Avatar
I would run the power leads for your camera into the fuse box. Find a terminal that is powered when the ignition is on and tap into there. This is how I used to wire all my radar detectors. I know you said you did not want to "hardwire" it,..so maybe this is not an option. But, aside from you cigarette lighter, I don't know of too many other options.
I just used some electrical blade connectors to do the job, but you could use a fuse tap product like this one.
Old Apr 3, 2014 | 12:57 PM
Ngarara's Avatar
Yeah, I run several things off the cigarette lighter, using a 4-way expander, and it definitely turns off when you lock the doors & thus take the car out of 'convenience' mode.
Old Apr 3, 2014 | 04:23 PM
richzak's Avatar
I like this idea and have never seen these before. Thanks so much for making us aware of this product and thanks so much for the photo.
Adding links and photos to a post really helps other members and saves time when researching products or ideas.
Old Apr 3, 2014 | 05:03 PM
amcdonal86's Avatar
Jeeze!!! What else are you running off of your cigarette lighter? A beer cooler?
Old Apr 3, 2014 | 06:10 PM
Ngarara's Avatar
Currently:
  • Valentine One (radar/laser detector)
  • Road Angel Gem+ (digital speedo & live-updated speed-camera database)
  • TomTom LIVE 940 (satnav with live-updated traffic)
  • [no. 4 was for iPhone power, in my XK8]
Have just received a mirror tap cable so will be able to power the V1 off the mirror soon, which will get rid of the dangly lead.
Hmmmm.... Beeeer cooler.....
Old Apr 4, 2014 | 06:03 AM
Jagst's Avatar
I have an MI Witness fitted. I had it done professionally as I did not want wires showing from rear camera. I also only wanted it working only with ignition on. He used a piggy back fuse in the fuse box in the passenger footwell ( right hand drive).
Old May 29, 2015 | 09:10 PM
haz783's Avatar
Hi Jagst
Do u know which fuse you piggybacked off?
Old May 30, 2015 | 04:50 AM
Jagst's Avatar
The fitter used the fuse box in the passenger footwell. He used a fuse that was only live with ignition on. Cannot have a look till next week.
Old May 30, 2015 | 04:21 PM
ralphwg's Avatar
Rich - Groupon has a Vaas dashcam for $25 as their lead item today.
Old Jun 2, 2015 | 08:50 AM
LoudHogRider's Avatar
As a heads up, Woot has dash cams on sale today. FYI...
Papago Dashcams - Electronics.Woot
Old Jun 5, 2015 | 09:44 AM
bart_redline99's Avatar
I am convinced that a dashcam is a no brainer given insurance deductible, the increase in distracted driving, and the potential for 'he said / she said.' I bought and installed the Spy Tech A-118 for $80 and love it (link below; no affiliation). The 1080p video is amazing, small and very low profile (out of my line of sight on the passenger side, high), 20 min to mount and hide the wire behind headliner and trim, with no visible wire. I have it running off the glovebox power socket - when the car is on, the cam is on. If you get this one, a) set motion detection to 'off' unless you have it permanently wired (not switched) on; and b) put or use the black side of the double-sided mounting tape toward the windshield.
A118-C 1080P Dash Camera w/ Capacitor HD
Bcrary3
Feb 21, 2023 04:29 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 01:40 AM
1964Daimler
Sep 9, 2015 11:28 AM
jaggermang
Sep 8, 2015 07:07 PM
