Dashcam switched fuse
Old Aug 24, 2019 | 12:05 PM
Rich Tea's Avatar
Default Dashcam switched fuse
I am trying to locate a fuse in the passenger compartment fuse box of my 2012 XKR convertible to use for a dash cam. I want to find a switched fuse (one where the power only comes on when the ignition is switched on). The owners manual is useless as the fuses are completely different to what is shown there. I have found a correct layout from a forum, but after using a voltmeter on a number of likely fuses (eg car accessory port) can't seem to find a suitable fuse. Any advice please? Thanks.
Old Aug 24, 2019 | 01:02 PM
JagRag's Avatar
Wire it to your cigarette lighter. (No one smokes in their car any more do they?)
Old Aug 25, 2019 | 03:55 AM
Rich Tea's Avatar
Thanks, I agree and would happily use that one but the fuse for the cigar lighter (their name since of course it is for cigars in a Jag not cigarettes!) is in the engine bay fuse box. I am looking for a fuse in the passenger compartment fuse box as that is where I have threaded the dash cam power cable through to.
I found this site with an XK layout jaghelp.com: Jaguar XK Fuse location and ID (I assume it is the same for the XKR) and have tried several fuse locations with optimistic-sounding names (eg 23 cabin accessory power) but when I test with a voltmeter it doesn't appear to be a switched source (ie says at 0v, even when ignition is on). I did the same thing on a Ford Galaxy recently and found a switched fuse location relatively easily, so I am wondering if things are different on a Jag (since they often are!). Any advice would be much appreciated.
Old Aug 26, 2019 | 02:11 PM
Rich Tea's Avatar
Have managed to locate a fuse that works, fuse No 16. All works fine.
Old Aug 26, 2019 | 07:19 PM
ralphwg's Avatar
Where is it located? under the Bonnet or behind the back seats?
Old Aug 26, 2019 | 11:58 PM
kj07xk's Avatar
Given the link in his post #3, I’d say it’s the one in the footwell, as he wanted something near the dash.
Old Aug 27, 2019 | 03:57 AM
Rich Tea's Avatar
Yes, correct. Passenger footwell on LHS.
Samantha
Dec 22, 2024 03:37 PM
obwoodie
Dec 12, 2015 10:01 PM
jimlombardi
Mar 31, 2015 06:08 PM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
gageman2000
Feb 17, 2010 10:22 PM
