Dead or Sleeping?
Old Mar 25, 2019 | 12:33 PM
jagtoes's Avatar
Originally Posted by HillmoorPete
No headlights, if I reattach the battery after getting it up to over 12.5 v, the panel lights come on but go off in a minute or so as the voltage drops.
Disconnect and charge the battery. LEAVE IT DISCONNECTED after it is charged and measure voltage. Should be better then 12.6 V. Let it sit for an hour UNCONNECTED and measure voltage. If below 12.6V then the battery is BAD
Old Mar 25, 2019 | 02:24 PM
Cee Jay's Avatar
After I had the battery charged I reconnected the positive terminal and checked resistance between the negative battery post and the negative cable. It is showing -.87 ohms. Could have been from the trunk open and key fob, but that doesn't seem like it could be a huge drain. What is normal drainage for the clock, radio, alarm etc?
Ohms isn't a reading that should have worked with a connected battery. Amps is the scale to use. If your meter was on Ohms, it would have blown a fuse.
Now, if your meter was on Amps, a reading of " -.87 " would make a LOT of sense. The " - " part because the leads were backwards, and the " .87 " as Amps would be a perfectly acceptable reading for a vehicle which just got connected. It would drop in steps down to probably .15 amps or so after about 30-40 minutes.
Old Mar 25, 2019 | 03:00 PM
Ranchero50's Avatar
What CeeJay said. You can sometimes get an ohms reading that way but it's not live. Check between the battery cables with the battery unhooked from one. I don't think it's worth doing before chasing the battery itself. Charge as said above with it disconnected and let it sit a while.
Old Mar 25, 2019 | 07:22 PM
HillmoorPete's Avatar
It looks as if the old battery was the culprit. I appreciate all the help and suggestions. A new Interstate battery has seemed to have done the trick. Everything is back to normal. Lessons learned:
Lock the car
Suspect the battery first
Multimeters are our friends
Step through the diagnostic suggestions above. It was all good advice.
Thanks!
Old Mar 25, 2019 | 09:00 PM
Stuart S's Avatar
And don't forget to buy a CTEK MUS4.3 from Amazon, even though it's your daily driver and some Forum members will tell you that a daily driver doesn't need a battery maintainer. It'll keep your battery fully charged, extend its life, and minimize electrical gremlins and aggravation. I look a CTEK as a cheap insurance policy, with nothing to lose.
Old Mar 25, 2019 | 11:26 PM
ralphwg's Avatar
LnrB
Dec 6, 2015 08:25 PM
mrtalkradio
Nov 19, 2013 10:37 PM
midknightbmw
XJ40 ( XJ81 )
Aug 14, 2013 08:16 PM
