Dead then alive
Old Feb 20, 2020 | 03:41 PM
Blues1's Avatar
Default Dead then alive
Drove my car today, made a couple of stops. Got back in the car after third stop and everything was dead. Screen was black, no click when I tried to start, no lights on the interior, no nothing. I could get the headlights to come on but absolutely nothing else. I inserted the fob into the slot in the console but made no difference. I stepped away from the car for a few minutes to make a phone call, come back and everything was back to normal. Drove it and made several more stops without issue. Seems as though the key fob wasn't connecting with the car. An fyi...I installed a new battery 2 weeks ago along with a battery tender connection and had it connected last night. I've driven it almost every day since the new battery with no hints of any issues. Any thoughts or ideas? I just changed the key fob battery as a precaution.
Old Feb 20, 2020 | 04:14 PM
Stuart S's Avatar
Intermittent power can be caused by a bad ground or loose battery cables. I suspect that whoever replaced your battery didn't adequately tighten the battery cables. Make sure that those cables are tight.
Old Feb 20, 2020 | 07:13 PM
Blues1's Avatar
Makes perfect sense. Didn't think about that.....will check tomorrow. Thank you
Old Feb 20, 2020 | 09:23 PM
BlkC4t_XK14's Avatar
This sounds familiar to me, when it was diagnosed as the alternator and the ground cable which has the computer on it.
Old Feb 20, 2020 | 10:46 PM
u102768's Avatar
It would be worth checking if this TSB has been actioned.
Old Feb 21, 2020 | 07:42 AM
Stuart S's Avatar
The OP has 2007 4.2L, which doesn't have the Battery Monitoring System with the module in the negative battery cable. That feature began with the 5.0L models from 2010 to 2015.
Silver cat
Mar 19, 2018 11:17 AM
steve_k_xk
Mar 20, 2017 02:39 AM
Stiffler4774
Jun 10, 2010 04:47 PM
jahummer
Feb 17, 2009 09:17 PM
redjagsport
Sep 21, 2008 04:57 PM
