Disconnecting seat heaters
Old Dec 23, 2025 | 12:56 PM
HealeyJag's Avatar
Default Disconnecting seat heaters
Scanned the Forums, no real help..
Seat Heaters are Caput, both of them..
Want to disconnect them to see if this helps my battery drain.....
In Florida so don't need them...
Thank you..
And Merry Christmas!!
Old Dec 23, 2025 | 02:59 PM
Circumnavigator's Avatar
Thank you..
I believe the connectors are under the seats in the front. So gotta slide that sucker back as far as it can go and twist into a pretzel on the floor.
One post I saw gave this warning.
”Disconnecting the under-seat connectors can trigger an airbag warning light if done unnecessarily (even if replugged), as the seat wiring is often integrated with the side airbag system.”
Was just one post, so it may or may not be true.
From what I saw…
Heated seats is Fig12.3 and airbags for a coupe is 18.2 in the wiring diagram for the 2008:
http:/jagrepair.com/images/AutoRepairPhotos/CarPDFFiles/2007XK/XK2008B20075toB32752.pdf
Doesn’t show a link between the two. So I’ll defer to the experts around here.
Old Dec 23, 2025 | 04:49 PM
Sean W's Avatar
Consider getting a workshop manual - several posted links on other posts. I'd post links for you but you don't have your model year in your signature.
Old Dec 25, 2025 | 10:48 PM
steve_k_xk's Avatar
When rebuilting my seats (motor replacements) i missed plugging the heater element back in and I can confirm it will throw an airbag code
Old Dec 26, 2025 | 08:25 AM
RoverJoe's Avatar
Community Influencer
DS002 in this example is your seat heater plug. It only has the 4 wires for the heater, so you should be able to disconnect it without triggering any other warnings. This is drivers seat for a random X150, I can double check with your specific model if you tell us what it is.
Old Dec 27, 2025 | 04:37 PM
HealeyJag's Avatar
Thank you..
going to leave it alone and charge car weekly!!!
was hoping for a needle in a haystack moment
Glyn Richards
May 8, 2024 09:14 AM
knares
Feb 21, 2024 07:53 PM
Samets
US Midwest
May 19, 2023 06:51 PM
AirCav
Dec 25, 2011 02:28 AM
