Displaying engine temp in the dashboard?
Old Apr 4, 2018 | 12:10 PM
gkubrak's Avatar
Default Displaying engine temp in the dashboard?
Is it possible to view engine temperature in the dashboard display?
Seems like a standard on every other car ever made.
This is for a 2008 XKR.
Thanks,
Old Apr 4, 2018 | 12:23 PM
Cee Jay's Avatar
Nope, and many people have tried to incorporate aftermarket ones. Some had better luck than others, what with GVIF inputs into the Touch Screen and also OBD displays on phones and tablets, then the dedicated small OBD gauges.
There are options, just none are super easy and good at the same time.
Old Apr 4, 2018 | 12:24 PM
Ranchero50's Avatar
No. You will need to use aftermarket OBDII connection gauges or run a stand alone gauge / sensor setup.
Old Apr 6, 2018 | 11:35 AM
Rey's Avatar
Rey
I have mounted a ScanGauge with velcro on my steering wheel "pad" (forward of the steering wheel). It is unobtrusive and quite small. It connects with the OBDII port (of course).
Old Apr 6, 2018 | 12:24 PM
jagtoes's Avatar
I did the same using the smaller scan gauge which just shows me water temp and voltage. I am not enamored with the looks but it serves it purpose.
Attached Thumbnails Displaying engine temp in the dashboard?-20170706_184803.jpg
ianritchie
Aug 22, 2017 12:15 AM
bdboyle
XE ( X760 )
Apr 17, 2017 09:30 AM
