Do you like the E-dip stick
Old Aug 8, 2014 | 07:27 AM
jagtoes's Avatar
Default Do you like the E-dip stick
I am still out in determining if I like the E dipstick instead of a real one. My kids Audi A4 has one but because the 2.0L turbo is an oil burner type engine we bought an after market dip stick as a back up. With that system it takes maybe a minute to do a read where the jag requires a min. of about 5 minutes. To bad you can't check it when it's cold . I have been resetting my gearhead mentality to adjust for the differences of daily checks of fluids and pressures to something that needs to be done every 2-4 weeks. This part makes it a little boring but the offset is I drive it more.
Old Aug 8, 2014 | 03:09 PM
bocatrip's Avatar
No, I don't like it and would prefer a real dip stick. Then again, I also wish I had a real temperature gauge!
Old Aug 8, 2014 | 03:12 PM
tbird6's Avatar
And a real transmission dip stick too!!
Old Aug 8, 2014 | 03:38 PM
amcdonal86's Avatar
I would like an E-dipstick. Where do I get one???
I think dipsticks can often be hard to read, especially if oil has gotten up the dipstick tube or if the oil is pretty fresh and isn't dark yet!
Old Aug 8, 2014 | 03:57 PM
jagtoes's Avatar
I can't help you on the hard to read problem because I don't seem to have that. Also if the engine is taken care of you should not have "dark" oil unless it is the color of the oil that you use. I have 30K miles on my Lexus (bought new) and change the oil every 5,000 miles using 5W-30 dino oil. It is as clean when I drain it as when I put it in.
LilaJagHubby
US Lower Atlantic
Mar 1, 2017 10:20 AM
adam699
Oct 13, 2015 05:53 PM
ArtyH
Oct 2, 2015 11:39 AM
goingjag
Sep 30, 2015 09:27 PM
pnwrs2000
Sep 30, 2015 01:56 PM
