Driver's seat stuck
Common problem, but usually in reverse with not able to recline far enough. A seat module reprogram is what you need. Either a Jag dealer or someone around with the Jag Land Rover program called SSD.
ALSO, to help everyone understand what you're asking, it is best to put your Model Year and Vehicle Specs in each post. Completing a SIGNATURE BLOCK helps a ton.
ANOTHER Also, a moderator will be along to ask you to go to the New Member thread (a must) and post a little blurb.
Welcome to the Forum. You'll find lots of helpful and knowledgeable members here. Learn to use the Advanced Search function because almost every question has already been asked and answered. Alternatively, Google can help you find the answers on this Forum if you use the right search words. And check out the "Stickies" at the top of this Forum for lots of tips.
Your seat is computer controlled, so just like your PC you may need to do a "hard reset" to reboot it. I think there's a sticky on how to do that. It's easy. If that doesn't work, then you'll probably need to have a Jaguar dealer or indy mechanic with Jaguar experience and the proprietary Jaguar SDD software to reset your car. See:
https://www.jaguarforums.com/forum/x...k-stuck-53099/
Since you're a newbie, if a post is helpful, you can press "LIKE" at the bottom right of the page.
Sue Pete Wentworth
Jul 19, 2022 07:35 PM
Surfer-J
Jul 13, 2009 06:46 PM
