Engine cut out
Old Jan 4, 2026 | 06:41 PM
chasr's Avatar
Default Engine cut out
Can someone help me pinpoint an issue with my 2007 XKR please. When starting the engine it cuts out in a few seconds. Almost as if the security system anti-theft system is shutting the engine down? Anyone have any insights. Thank you.
Old Jan 4, 2026 | 07:16 PM
RoverJoe's Avatar
Community Influencer
Any faults? Do you get the security light flashing on the dash? I don't think that would allow it to even start but the older Ford systems sometimes did that, run for 2 seconds and die.
Do you have access to any diagnostic tools? I would start with looking at live data and watching fuel pressures.
Old Jan 4, 2026 | 08:32 PM
chasr's Avatar
The check engine light stays on and the engine stops within seconds. Engine starts normally .I do not have diagnostic tools. It starts normal and within seconds stalls out as if fuel flow has been halted. I'm going to try again tomorrow. Thanks.
Old Jan 4, 2026 | 08:43 PM
kj07xk's Avatar
Does this happen on cold starts, or on restarts after the engine is warmed up? (Or both?)
Old Jan 5, 2026 | 05:11 AM
guy's Avatar
guy
Check engine light on, shuts down immediately… and you’ve come to the conclusion that its a security issue??
Best get it flat bedded into the shop.
Old Jan 5, 2026 | 06:30 AM
chasr's Avatar
this time a cold start. This did happen one time during a warm start several years ago, but eventually started and has not reoccurred until now.
Old Jan 5, 2026 | 08:41 AM
bgpenguin21's Avatar
I would definitely suggest investing in a OBD2 scanner. They are so cheap anymore. Even a $25 model can read the "check engine" codes for you.
Old Jan 5, 2026 | 10:43 AM
JagV8's Avatar
You're flying blind without the codes and an OBD tool which can read live data. E.g. elm327
Old Jan 6, 2026 | 02:39 PM
chasr's Avatar
Default Obd read
Okay picked up one of these devices. In the meantime the car has started and is running fine? Currently no check engine light but I may have cleared that learning how to work this thing. Here is what I'm getting from obd:Car Scanner. ELM OBD2
Version: 2.0.58/42000058/GP
DTC report
Connection profile: Jaguar OBD-II / EOBD + extra (CAN)Date: 1/6/2026 3:30:32 PM
VIN: SAJ
OBD-IIOBD-II
DTCs: 131
P0193 [0x0193]
Fuel rail pressure (FRP) sensor - high input
Status: Pending
P0193(00) [0x019300]
Status: Test failed (current drive cycle), Pending, Test not completed since last DTC clear, Test failed since last DTC clear
Am I assuming correctly the first step is to replace the sensor?
Old Jan 6, 2026 | 03:27 PM
RoverJoe's Avatar
High input is most likely a shorted sensor, yes. You could test the voltage at it and verify the wiring, but the sensors do go bad. A false high reading will cause the pump to be slowed down to 'lower' the pressure, which would cause a loss of fuel pressure and a stall like you were getting. So it's a good place to start.
Old Jan 6, 2026 | 05:44 PM
chasr's Avatar
Thank you. I will do that looking up the p/n now. The car started fine today I drove it for about 30 minutes performance seemed fine returnrd parked it went to start 2 hours later and had a heck of a time getting the engine started again. Finally started so I could get it in the garage. Engine light back on.
Old Jan 8, 2026 | 08:45 PM
chasr's Avatar
Thanks Gents for the help here. The fuel pressure sensor it was. Local shop here in Palm City made the repair today. Back in the saddle. Appreciate the assist here.
jayd2
Jun 25, 2025 09:07 PM
Lycaon
Feb 27, 2023 12:11 PM
XKRRR
Apr 24, 2020 09:24 PM
Colt23
Aug 31, 2017 07:00 PM
Joel Moross
XJ40 ( XJ81 )
Jun 9, 2017 07:21 PM
