Engine RPM fluctuate and vibration at cold start
Old Oct 27, 2019 | 05:19 AM
renskys26's Avatar
Post Engine RPM fluctuate and vibration at cold start
I have issue with my XKR (x150) where the rpm fluctuate dramatically as the idle stabilizes at cold start especially in the morning. As the rpm trying to settled down with the needle pointer between 1000 to 2000 rpm. I can feel vibration from the body it seems like the engine is going to shut off like a feeling of detonation. RPM will stabilize in a few seconds and slight vibration will be there. No trouble code registered, no misfire data, no engine light, all engine and transmission mountings are OK. cat converters and sensors are all new. The car mileage is 41k miles.
Are these normal condition? I recently bought this car.
Please advice if you have encountered same issue. Thanks
Old Oct 27, 2019 | 10:39 AM
JagV8's Avatar
It is probably still running open loop and cannot figure what code(s) to flag.
It doesn't sound normal.
When running happily, do the usual fuel trim tests in case you get clues.
Chuck Schexnayder
Nov 3, 2020 10:50 AM
theweeb
Sep 17, 2016 04:35 AM
L80ous
Jul 13, 2014 12:53 PM
Elbartus
Apr 19, 2013 11:22 PM
jaggernl
Mar 28, 2009 03:42 PM
