Exhaust Tips Discoloring
My 2012 XKR-S suffers from discolored exhaust tips on the outer pipe on both sides. I have gone to the dealer who said this is common on all XKR/XKR-S cars. Having previously owned BMW M and Mercedes AMG vehicles with quad tail pipes that never suffered from this malady, I wonder if anyone else is having this problem. I expected a Jaguar to have the same quality as those other brands.
Metal polish has been tried as a remedy without results. The tips have a gold tinge to them.....much like what is seen on a chromed motorcycle header pipe, which I believe is caused by heat.
Is this just something I need to live with? Or has someone has success with this issue? Or, am I the only one with a problem!
I'll check mine when I get home, but I think they are pretty clean. I keep my car spotless, and my detailer even cleans out the inside of the tips. If there is a slight tinge it doesn't stand out for sure.
Mine are OK. How many miles on your XKRS? I'm at only at 9000 miles, but I wash the car 2,3,4 times a week during the summer.
Is your 4 pipes are affected? Maybe the direct pipes get more hot (the outside ones)?
Guy
Guy
Ok guys, I'm not lucky enough to own a fantastic vehicle like yourselves, but surely this is detailing related?
This is mine below on my A6 and they look almost as good as when they left the factory, with now approaching 110k miles on her
I ALWAYS include them in my wash routine and generally just use soap and water.
As stated, perhaps some Autosol or other similar metal polish will bring them back?
Good luck
Good luck
Wow Jim, you car looks brand new.
I think I have seen what he is talking about...Maybe it is heat combined with some kind of chemical or cleaner that could have stained the metal. But I honestly I have no idea....just a guess.
Can you take a picture?
Interesting Post......
My 2009 Jaguar XKR with 14,850 miles shows NO signs of discoloration on the quad tailpipes...........
however..........
My 2014 Porsche Cayman 981 with just 781 miles shows minor discoloration around the edges of the single tailpipe.
I believe this may be due to the heat from the exhaust and a difference in the type of metal used on the tailpipe.
The Jaguar pipes on the XKR are a very nice chrome, which the Porsche is NOT chrome, but more of a brushed type finish.
In this case or issue, the Jaguar out performs the Porsche for tailpipe discoloration.
The photo of the Porsche tailpipe below was taken at only 150 miles, now it is beginning to show some discoloration.
however..........
As I stated earlier, I have never had this problem with either my BMW M Coupe (regrettably sold after 80,000 miles...biggest mistake ever!) nor my last Mercedes AMG (sold with 76,000 miles).
Thanks for all the responses.
Take the tips off, put on a buffing wheel to get totally polish and then monitor. I wash the exhaust tip every wash, as well as inside the exhaust as far as my wheel brush will go and the muffler too.
The outside pipes are the ones use on the dinamic mode. You probably always use it?
https://www.jaguarforums.com/forum/a...ve-exhaust-jpg
I suppect some over heating and more fumes. The center pipes stay clean because they're never in fonction maybe?
Guy
Guy
If you take metal polish compound but instead of rubbing with a rag or sponge work it in with 0000 steel wool, it should take care of your problem. I have used it on my exhaust to clean on many occasions. Make sure it is 0000 and not anything coarser.
Guy
Guy
Unfortunately the 'tips' are not detachable as they are a part of the one piece muffler/tailpipe assembly. I can see Jaguar USA's hesitancy to replace the entire assembly as they want to sell it for about $4,000!
I'll try your suggestion (on the underside of the pipe nearest the front so that it will not be noticeable if I goof it up), but I think from looking at your photo that the tailpipe material may be different on our two vehicles.
Back in the day, exhaust tips were electroplated with chrome. Because that process is harmful to the environment, it is being phased out. Most "chrome" wheels today are PVD. I suspect your exhaust tips are polished stainless steel, which is harder and more durable than PVD. If so, they should clean up well with 0000 steel wool, as mentioned above, and a good metal polish such as Brasso.
mikiep
Dec 20, 2019 07:37 PM
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
Oct 2, 2015 12:13 AM
baskervillema
Oct 1, 2015 06:43 PM
