fabricate air scoops
Old Feb 11, 2018 | 09:57 PM
jahummer's Avatar
Default fabricate air scoops
One of several projects I am working on is improving air intake flow on my "air pump" engine.
I saw this the other day which may be a great solution for plumbing directly to the filter boxes as well as eliminate those hideous fog lights/grilles.
Any one here have fabricating or prototyping skills or suggest a direction to take? The existing ones pop right off so it should be easy to replicate the part.
I like the front splitter too...
Old Feb 11, 2018 | 10:23 PM
Stuart S's Avatar
I suggest that you check with Chris at Mina Gallery and see if he has any interest in adding this to his inventory of performance mods.
Old Feb 12, 2018 | 06:44 AM
jagtoes's Avatar
I like the look and if functional then great.
Old Feb 12, 2018 | 06:51 AM
mosesbotbol's Avatar
Are those for the air box or the brakes?
Old Feb 12, 2018 | 07:39 AM
Ranchero50's Avatar
Brakes. For engine I think you'll need a balance duct from one side to the other to avoid the unbalanced MAF signal CEL code. Since removing the snorkels on my stock air boxes I've gotten it twice. I figured a 3" diameter cross over duct plumbed after the air filters should work well.
I like that opening profile and I would still mount the fog lamps in the opening for improved night driving. They do make a difference.
Some Google image search shows the car was built by these guys. Maybe they have spares from 2010 sitting on a shelf somewhere.
http://tripleeight.com.au/
Old Feb 12, 2018 | 07:57 AM
Ranchero50's Avatar
Ah, pity. The car was a proposal that never saw the light of day. No wonder there's so little info on it.
A Closer Look At The Privateer Jaguar GT Programmes ? dailysportscar.com
Old Feb 14, 2018 | 01:57 PM
Panthro's Avatar
Didn't the Palmer race XKR's have something like that on them?
Old Feb 14, 2018 | 07:22 PM
jahummer's Avatar
Yes and others as well, but much larger and riveted. These looked to have been designed as a snap-in replacement for the originals.
I can't speak for what use they were intended, but since the air filters are right there, my idea was to plumb direct to the intakes. I already have brake cooling ducts fitted to the under carriage.
Old Feb 17, 2018 | 09:21 AM
jahummer's Avatar
Air intakes probably, the brake ducts are under the car.
Old Feb 18, 2018 | 12:57 AM
Stuart S's Avatar
My clothes dryer has the same ducts! It must be supercharged!
Old Feb 18, 2018 | 06:46 AM
jagtoes's Avatar
Taking a look at the hose length and routing I guess I would have considered some kind of hood scoop where you can get a direct route into the S/C. Just a thought.
Old Feb 18, 2018 | 07:55 AM
Ranchero50's Avatar
We don't know what's attached to the ends. Looks like the engine harness is original so I suspect there's some flavor of mass air meters at the end of the hoses.
Also note on the near side that there is a black 4" hose feeding the brakes.
Old Feb 18, 2018 | 09:08 AM
jagtoes's Avatar
Yep understand so just need to be a little creative on the MAF but as with all mods things need to be thought out and see what kind of options you have. Also maybe a scoop would be an air flow issue but just thinking out of the box. Also does the 4.2 SC use 1 MAF or 2 like the 5.0 SC. Seems like the rest of the world except Ferrari uses 1 MAF .
Old Feb 18, 2018 | 09:28 AM
jahummer's Avatar
There are 2 which complicates things because both want to see the numbers with little room for error. This has been demonstrated when having mismatched air filters.
chXFS
Dec 21, 2014 01:47 AM
SexyBeast
Apr 26, 2013 05:27 PM
Plant
Jun 7, 2012 10:19 AM
Mayor111
Nov 3, 2010 08:12 AM
McJaguar
Jan 10, 2009 06:35 PM
