Forged Vortex Wheels
Old May 29, 2019 | 09:10 AM
D1FWS's Avatar
Default Forged Vortex Wheels
Hello
i have a 2009 4.2 XKR with Alcon brakes and forged vortex wheels.
I believe that the parts number for these wheels is:
C2P17497 (front)
C2P17498 (rear)
Recently I purchased two vortex wheels, hopping that they are identical apart from the colour/finish:
C2P25174 (front)
C2P25175 (rear)
Can anyone advise me?
thanks in advance
Old May 29, 2019 | 11:59 AM
Cee Jay's Avatar
Originally Posted by D1FWS
Hello
C2P17497 (front)
C2P17498 (rear)
C2P25174 (front)
C2P25175 (rear)
thanks in advance
I did a quick Google Search for ONLY the C2P25175 (rear) as all the Fronts should be identical, and out of eighteen results, all eighteen were for the 2010 and later 5.0 cars, but I could not find any with offset information. Going by the ONLY for later models I would greatly assume that the offset is 46mm on the one you ordered and not the 29mm needed for earlier cars.
Google Search of C2P25175
Old May 29, 2019 | 12:55 PM
MarkyUK's Avatar
FYI I have vortex wheels and they are defo not forged*, nothing in the XK/R range was forged IIRC excepting those fitted to the GT-RS
I know this as have weighed them, for the size forged alloys would be at least 5lbs lighter per alloy
Old May 29, 2019 | 01:18 PM
jahummer's Avatar
There are 2 versions. The original silver versions WERE forged and had a 26 rear offset. Jaguar re-released them several years later for the face-lift X150 in a cast version, gloss black with machined face, lower price and applicable rear offset for the new E-diff.
Old May 29, 2019 | 02:08 PM
Tervuren's Avatar
There was never enough information to conclude if what you have are replicas or not.
The two people with weights both bought them online instead of being OEM.
That said, the same design of wheel; forged vs cast, will weight about the same.
The advantage of forged wheels is not tensile strength, lighter weight material, or stiffness.
The advantage is the forged material can deflect for more cycles without damage and can deflect farther without damage.
This does allow the designer to work to different tolerances in the design when it comes to forces when in use. This is why some forged wheels are lighter than some cast wheels.
However with same design of wheel in either process there won't be an extreme difference in weight.
For a racer running up on curbs and making hard contacts; the difference between a cracked wheel and driving off from a hit can be forged vs cast.
An important aspect of modern low profile tires and their larger wheels is stiffness. This stiffness requires more material and weight.
Everything I have read is that the original 4.,2L XKR-S came with Vortex Forged wheels.
Later a cast version in similar styling came out as a Vortex Cast wheel.
aholbro1
Mar 15, 2019 03:50 PM
dag82
Dec 1, 2017 05:56 AM
jleuz1
Mar 9, 2015 08:23 AM
gavmick00
Sep 24, 2014 08:12 AM
