Front passenger side turn signal problem
Old Sep 11, 2020 | 04:56 PM
badicedog's Avatar
Default Front passenger side turn signal problem
Hello guys, I have a 2009 XK. The front passenger side turn signal stopped working and I got the message on the dashboard. I replaced the bulb but it did not remedy the problem. I'm asking for any suggestion on how to fix the problem. Have any of you encountered this before?
Old Sep 11, 2020 | 06:18 PM
George05's Avatar
Ihave read of this on other models, google it up
Old Sep 11, 2020 | 06:19 PM
JackJohn's Avatar
BiD, exactly what did the message say?
Old Sep 11, 2020 | 07:17 PM
badicedog's Avatar
This is the msg
Old Sep 11, 2020 | 08:20 PM
Stuart S's Avatar
I suspect a bad ground connection from the right headlamp. See Post #6 in this thread:
https://www.jaguarforums.com/forum/x...solved-198031/
Good luck!
Old Sep 11, 2020 | 09:57 PM
badicedog's Avatar
Good luck!
thank you Stuart
Old Sep 11, 2020 | 10:11 PM
Stuart S's Avatar
You're welcome.
If a Post has been helpful and you want to say "Thanks!", press in the bottom right corner of that post.
That's why it's there.
Old Sep 15, 2020 | 09:54 AM
You're welcome.
Of course you may it ....... but we don't have a button for that. It wore out and we never got round to fixing it.
Old Sep 15, 2020 | 10:05 AM
Stuart S's Avatar
Old Sep 29, 2020 | 07:10 PM
badicedog's Avatar
After a very lenghty disassembly and inspection I have found the culprit. All wires, harness, grounding points were in excellent condition. It wasn't until it occurred to me to switch headlight assemblies that it was clear the headlight assembly is the culprit. This car is well taken care of with only 30k miles and all due maintenance has been done. Before I go spend 2k on a headlight assembly, any other Ideas? I was thinking of using a multi-meter to to check for any broken wires withing the headlight assembly.
Old Sep 29, 2020 | 11:37 PM
kj07xk's Avatar
There are at least 2 threads in this forum where an owner has encountered bad/missing insulation on wiring inside the headlight. Seems to dissolve over time. They were able to repair them.
Old Sep 30, 2020 | 12:23 AM
u102768's Avatar
As kj07xk said, there have been a few people have issues with the wiring inside the headlights. Have you seen this thread?
https://www.jaguarforums.com/forum/x...ailing-224587/
Old Oct 9, 2020 | 11:59 AM
badicedog's Avatar
After careful inspection and disassembly of headlight housing, I found the potential culprit. The turn signal socket, there is a broken contact within the receptacle. Any ideas where I can find one? JLR doesn’t sell it without the $3400 complete headlight housing.
Old Oct 9, 2020 | 12:03 PM
Cee Jay's Avatar
Fix it with stuff?
I use formable JBWeld putty for hard parts, and contacts can be made from any old copper or brass sheeting.
Old Oct 9, 2020 | 02:33 PM
kj07xk's Avatar
Should be able to find a cheap broken headlight, since you don't care about the front of it or its appearance. Try the auto breakers, or ebay?
Old Oct 9, 2020 | 03:50 PM
badicedog's Avatar
06-09 Land Rover socket fits our cars! Thanks for the help guys!
jomo
Dec 24, 2017 06:39 PM
XJL
Mar 25, 2015 06:27 PM
solerunner
Sep 18, 2011 05:18 AM
firetapped
Aug 4, 2011 03:03 PM
SeismicGuy
Feb 3, 2010 11:04 PM
