Front and Rear grooved/slotted discs
Old Jul 13, 2016 | 05:24 PM
powerhouse's Avatar
Default Front and Rear grooved/slotted discs
Soon getting the rear discs and pads fitted to my 2007 xkr. The car is fitted with rear slotted and grooved discs, from previous owner and the front are just the jag spec flat disc. I think i'm going to change the front discs for the grooved and slotted type like the rear. Anyone have them fitted and what type they used, pics would be nice.
Old Jul 13, 2016 | 08:09 PM
tberg's Avatar
I have slotted and drilled rotors on all four wheels. My mechanic has a source that custom makes them. I had the first front set replaced a couple of days ago as they had started to shimmy on high speed (freeway) deceleration. The new ones are worse and will be replaced under warranty (less than one day of use before I knew there was an issue). But I was very happy with the previous set which probably lasted about 25K miles. I believe Stop Tech manufactures drilled and slotted rotors for the XKR, here in the states.
Old Jul 14, 2016 | 06:30 PM
flyc2c's Avatar
https://www.jaguarforums.com/forum/x...-today-161113/
NCJagman
Apr 15, 2016 12:40 AM
powerhouse
Apr 2, 2016 02:55 PM
Jun 3, 2006 12:59 PM
Humy
Feb 16, 2006 01:45 AM
Audio/Visual Electronics
Jul 29, 2005 07:22 PM
