Fuel pump access
Old Sep 3, 2019 | 11:39 AM
chazaroo's Avatar
Default Fuel pump access
When I turn the car off, I intermittently hear a sound like a pump running. IT's coming from somewhere at the rear of the car. I was wondering if it's a fuel pump problem? Is there a way to access the pump without dismantling the car?
Old Sep 3, 2019 | 12:13 PM
Sean W's Avatar
Could it be the Navigation Drive running in the boot? And I think the answer to your second question is no since the pump is in the tank. Some dismantling required.
Old Sep 3, 2019 | 12:19 PM
gkubrak's Avatar
I have the same issue thing. Its a normal leak check the ECM performs every now and then.
Thought it was my pump but i'm positive it's this guy:
You can read all about the Fuel tank leakage monitoring system in the repair manual, PG 1864. Note this is from MY 2008 manual but i'm assuming the 2010+ have the same system.
You can hear it after you shut the car off, but not every time right? Next time it comes on, turn the car back on (no ignition) and back off. It should go off.
Old Sep 3, 2019 | 01:00 PM
SeanU's Avatar
This test is why you get a warning if you don't tighten your gas cap.
Old Sep 5, 2019 | 10:23 AM
chazaroo's Avatar
Great, thanks!
romroc
Nov 14, 2017 10:01 AM
plums
General Tech Help
Jan 17, 2016 02:28 AM
Toybreaker
Nov 17, 2015 03:22 AM
georgeryoung
XK120 XK140 XK150
Jun 23, 2015 09:28 AM
Zolomoro
Jan 14, 2015 03:33 PM
