Gremlins moving in to my 2007 XK?
Old Dec 9, 2024 | 04:11 PM
2007 XK Convertible 30k miles's Avatar
Default Gremlins moving in to my 2007 XK?
The car is not responding to the fobs (new battery and it initially worked after replacing), cruise control not available warning on screen, passenger door has to be unlocked manually. Could all these things have something in common? Have to start the car by placing fob in console and that doesn’t feel like a long term solution. Help please! This is my daily driver and my wife is still mad about me trading for it.
Old Dec 9, 2024 | 04:17 PM
Default One more problem
Also the key fob is not working on the exterior button to lock the doors. One person suggested I try this.
NBCat's Avatar
Use a voltmeter to check the available voltage across the battery terminals with the ignition in the OFF position for 30 minutes or longer. There should be a minimum of 12.6 volts available, if not, charge the battery for five hours at 2 to 5 amps and retest.
If the voltmeter indicates less than 12.6 volts available, the battery is suspect and should be replaced. The vehicle needs at least 12.6 volts available for all systems to function properly.
Many of the electrical 'gremlins' chased across these forums are the result of a failing or weak battery.
Old Dec 21, 2024 | 10:59 AM
Sampson's Avatar
Had same issues with my 07 XK. Replaced alternator and all is well. Even the cruise control started working😎
Sampson
Feb 21, 2023 09:27 PM
V7Sport
Aug 19, 2021 10:52 AM
Seil39
Mar 6, 2020 01:43 AM
aratnam
Sep 18, 2015 09:31 AM
Typhoon320i
Mar 1, 2015 01:34 AM
