H8 cornering bulb, not blown,but not working
Old Jun 1, 2014 | 08:55 AM
powerhouse's Avatar
Default H8 cornering bulb, not blown,but not working
fitted some canbus error free sidelight bulbs today, and noticed one of the cornering bulbs, the one under the sidelight bulb was not on. Took it out and tested it, working fine. Any ideas of problem, is there a fuse for this bulb or are the lights combined on the same fuse. Cant see in manual
Old Jun 1, 2014 | 12:33 PM
CleverName's Avatar
Helps if I read your post...sorry..
Did you invert the bulb? Am I understanding you just swapped them for LED bulbs?.... They only work when inserted one way... Rotate it 180% and check it again...
BOL
-Vince
File Type: pdf
Old Jun 1, 2014 | 04:29 PM
powerhouse's Avatar
Default h8 bulb
sorry for the confusion but i didn't change the h8's to led yet, they are still the standard bulbs, just the sidelights. IT's just one of the stanard bulbs is out, but tested it when removed and is good, but wont work when fitted, is there a fuse
philwarner
Sep 5, 2015 10:05 AM
pocketrocket
Sep 3, 2015 07:44 PM
arnoldmilk
Sep 3, 2015 07:42 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
XJsc-guy
Sep 2, 2015 11:43 AM
