Has anyone replaced the rear lower strut bushings
Old Apr 11, 2021 | 01:28 PM
Sean W's Avatar
Default Has anyone replaced the rear lower strut bushings
I'm ordering rear upper and lower control area and stabilizer end links. Going with Mevotech. I noticed the lower bushes on the strut looked pretty haggard. I'm thinking might as well replace them but I don't want to mess up the strut. Has anyone pressed them out? Can it be done in situ or will I need to remove the strut (yes I'm lazy).
Thanks for your help.
Part number for the bushes are URO - C2D4013
Old Apr 12, 2021 | 09:14 AM
gkubrak's Avatar
I considered this when I did my control arms. Passed it up because I didn't want to buy a whole press kit and try to find the right size adapters. Also my bushings were still OK.
I don't see how you can replace them while the struts are still in place. An extra 4 nuts from the top will let you remove the whole thing. Then you can check the spring and seat for any wear/damage.
Old Apr 12, 2021 | 09:51 AM
Sean W's Avatar
Thanks. I read where someone did it with the struts still in place on the X350 forum but not a big deal. Bush press kits are free to rent from auto parts stores around here. I bought the bushes and will examine closer when I replace the control arms. I just eyeballed and they looked rough, but easy enough to check once it's on the lift.
dauraf
Jun 21, 2019 09:30 PM
XxSlowpokexX
Dec 3, 2015 05:18 PM
XxSlowpokexX
Nov 17, 2015 12:22 PM
otisbd
Sep 17, 2013 05:34 PM
jimmycruz99xjr
Sep 30, 2011 09:53 AM
