Headlamp washer MOT fail
Old Oct 2, 2024 | 10:09 PM
wymjym's Avatar
Originally Posted by XKDreams
Sorry, this is no help. But, you’d do better pissing on the headlights than using the washers. Their operation and functionally are pathetic,
my stream isn't what it used to be, so I'm not sure
WJ
Old Oct 12, 2024 | 11:56 AM
Joe CW's Avatar
Ok so these are the offending parts. Nearside (left) is stuck slightly out, but otherwise okay - it is not blocked and it moves out and springs back. Offside (right) was stuck solid; I’ve managed to get it moving but it’s blocked and I can’t blow through it.
I managed to remove the end jets but cannot work out how to dismantle any further to clean effectively.
Old Oct 12, 2024 | 05:46 PM
guy's Avatar
guy
will a vinegar solution help?
Old Oct 13, 2024 | 05:40 AM
Spurge's Avatar
Default 10 minutes HL washer timer
Originally Posted by Cee Jay
Since they only operate every fourth cycle, it'd be more likely that either the relay that opens the line or that which activates the relay is faulty.
My Manuel is saying: Every fourth cycle but only after 10 minutes since previously operating.
I've just been MOTed. To allow the 10 minutes reset I was careful not to use the washer on the way to the test.
I'd not seen the HL washer working before, it's probably not noticeable from inside the car whilst the windscreen washer is operating. I was pleased to see a vigorous spray.
(MOT passed, with one advisory a number plate bulb. &#128512
Old Oct 13, 2024 | 06:13 AM
guy's Avatar
guy
Glad you passed.
But that is inaccurate; you should be able to tell immediately when the headlight washers are activated.
Old Oct 16, 2024 | 11:22 AM
Cee Jay's Avatar
Originally Posted by Joe CW
..............................I managed to remove the end jets but cannot work out how to dismantle any further to clean effectively.
Ultrasonic parts cleaner???
Old Oct 16, 2024 | 11:34 AM
Cliffords's Avatar
I also got an MOT last week and I am sure they were not tested, nor do I think mine work. It's a bit inconsistent isn't it .
Old Oct 16, 2024 | 02:05 PM
  #28
Cee Jay's Avatar
The washer would need to be operated up to four times to properly test headlight washer operation, to make sure the count was reached. A quick glance at the headlights after operating the windscreen washer would show either wet or dry.
Old Oct 16, 2024 | 03:30 PM
gmuirnz's Avatar
My understanding is that the Headlamps/headlights must be ON for the washer to work. I see the overspray from the headlamps when using the windscreen wash function at night, but not during the day.
Jag69
Dec 28, 2020 01:31 PM
MussieRon
Jul 12, 2020 11:58 AM
NTL1991
XJ40 ( XJ81 )
Sep 13, 2013 01:00 PM
AndersA
May 31, 2013 04:20 AM
