Headliner Material Source? Oyster / Ivory interior
Old Feb 21, 2021 | 09:31 PM
mosesbotbol's Avatar
No reason you couldn't two colors between the pillars and headliner. Ultrasuede for the pillars and wool pattern for the headliner.
Old Feb 22, 2021 | 06:46 AM
Clellandm's Avatar
I was thinking of that while pinning the headliner up yesterday. Ted is sending a black and a grey sample and I think a contrast might look good - until the thing fell on my head I don't think I could have told you what color it was!
Old Jul 30, 2023 | 08:49 AM
Rover Stormer's Avatar
Default Need help here d'eau Tberg
Originally Posted by tberg
GordocatCar,
A similar suedecloth, commonly known as Passion Suede, is available in approximately 100 colors, and is very inexpensive (well under $10.00/running yard-60" width). I have used thousands of yards of it over the years for client's decorating needs. If you need a sample, I can clip from my sample books, and can get you any color you could imagine. Wholesale it's about $5-6/yd depending on source.
Can I PM you on this subject, writing to you from Ottawa in Canada
Old Jul 30, 2023 | 10:04 AM
tberg's Avatar
Of course. I will get back to you right away.
Old Jul 30, 2023 | 02:25 PM
bocatrip's Avatar
For my personal tastes, "two colors" just doesn't look correct for me. I had a very hard time repairing mine, and ending up using the original material for everything, which ended up working ok, (not perfect) but everything matches well. Even the sunvisors were done (which most installers stay away from). Next time around (if I'm still alive) I'll change the color to a dark one and do everything all over again without the foam.. Yes, the foam does screw things over as it does fall apart eventually. I'd advise against using foam but instead a superior thicker material that stretches glued directly to the headliner and trim pieces. Change "everything" including all 6 trim pieces as well as the headliner. Everything eventually sags with the foam, but eliminating the foam is the best way to go. Call Tberg
Old Aug 3, 2023 | 05:36 AM
Was able to get in contact with him, thanks.
The guy is sooo responsive, unbelievable
tberg
Oct 2, 2025 04:04 PM
Ubad2
Jan 22, 2025 08:24 AM
mhamilton
Jun 1, 2015 03:05 PM
mgb4tim
Jun 15, 2012 10:24 AM
scottatl
Sep 13, 2010 01:02 PM
