headliner problem
Old Dec 24, 2017 | 01:42 PM
chazaroo's Avatar
Default headliner problem
While I was driving this afternoon, the headliner just behind the driver's seat, started coming down. It looks like its about an 18 inch square section. Anybody had experience with this and if so, how did you fix it?
Old Dec 24, 2017 | 03:04 PM
Sean W's Avatar
Haven't done a coupe but you need to replace, not repair. Headliner material has foam attached and the foam disintegrates over time.
So do you plan to do it yourself? There are companies that come to you (like glass installers). On the X350 forum, I've read prices as low as $150 for the service.
If DIY, fabric stores carry headliner material. Service manual should cover the procedure.
Old Dec 24, 2017 | 03:13 PM
chazaroo's Avatar
Saw a couple youtube videos on replacing. Not going to tackle that job so I need to find someone who does it. Jaguar of Palm Beach has $595 listed for the headliner. And that's just the part. Yikes.
Old Dec 24, 2017 | 04:02 PM
ralphwg's Avatar
There are a couple of threads on this issue. Check them out.
Old Dec 24, 2017 | 04:30 PM
shemp's Avatar
I had mine replaced at a local headliner repair place. T'was $500 and took about 3 hrs while I waited. Material is very close to the original color and texture.
Old Dec 24, 2017 | 08:03 PM
Ranchero50's Avatar
I did it myself. Lots of stuff need to come out to fish it out of the car. Pics and details in my build thread. Wasn't horrible but took a good two days at a pretty slow pace.
Getting the old foam off the board absolutely sucked.
Old Dec 24, 2017 | 08:17 PM
IanXF's Avatar
Replaced mine myself 08 coupe wasn’t that hard just go slow don’t over glue used suede from auto trim online with foam backing
Old Dec 24, 2017 | 10:28 PM
steve_k_xk's Avatar
+1
I used a trimmer cost me approx $130 by memory, however removing the old glue with a plastic scrapper was not fun at all
Old Dec 24, 2017 | 10:39 PM
Sean W's Avatar
Keep shopping. Look for a local service that specializes in it.
Old Dec 25, 2017 | 01:37 AM
1 of 19's Avatar
Just had mine replaced. Took it out myself and dropped it off at the upholstery shop. $150.00
Old Dec 28, 2017 | 09:56 PM
TXGladiator's Avatar
I had exact same issue on my 2012 XKR-S w/ leather headliner. Took to upholstery shop and discovered that Land Rover and Jaguar both have this issue - especially common in warmer climates. Their shop had several NEW Rover's in for this exact repair. Also happens on Ferrari and Bentley's too.
Its exactly as Sean W stated - the thin foam and adhesive used to attach the leather to the headliner board easily degrades - especially in warmer climates. Upholstery shop said this is a "known issue" ...
So I contacted Jaguar Customer Care (800-452-4827 option 9, Ext. 1309040), explained the issue and asked specifically for "Goodwill Consideration". I sent pictures of the sagging headliner, provided my VIN, etc. A few days later they called back, offered to pay for 25% of the headliner replacement cost - 25% because I've only owned the car less than 4 months. I would, however, HAVE to have it replaced by my local Jag dealer. But, still worth a try to call Jag corporate - particularly if you are a long time owner. Jag corporate stepped up, even for a new owner!
My local dealer, however, wanted $1,600+ to replace the leather headliner... Since I couldn't see replacing it with another faulty OEM piece and risk the same issue again, I opted to have the upholstery shop remove it, strip the foam and adhesive from the leather and reattach with quality adhesive to the headliner board. It looks like new. That was $1,200 but they guarantee their work for as long as I own the car...
** Tip for all ya'll with leather dashes and headliners - be sure to put leather conditioner on them frequently. Leather drys, then tightens, pulls at seams, then splits, etc. Upholstery shop owner swears by this stuff:
Chamberlain's Leather Milk Chamberlain's Leather Milk
(https://leathermilk.com/). Works great.
Good Luck!
Old Dec 29, 2017 | 08:40 AM
chazaroo's Avatar
Found a shop in West Palm with a good reputation. They will remove, clean and re-glue using existing liner and new backing. $275. Taking it in next Tuesday.
Old Dec 29, 2017 | 09:07 AM
GordoCatCar's Avatar
My 2011 coupe's headliner (oyster/ivory) used the 'canvas' light beige material which was very difficult to replicate. The upholsterer I used ended up recovering the headliner and all the adjacent panels like A pillars, back frame, etc. Total job was $400.
I asked about reusing the existing material and he didn't want to do that in spite of the fact we were having difficult sourcing a color/material match from various vendors. Keep us posted on your opinion of the results.
Old Dec 29, 2017 | 09:13 AM
chazaroo's Avatar
Will do. The folks at this place said they've done lots of them. The only price I got on replacing with a new headliner was $700. And Jaguar of course would want much more than that. I figure $275 is an appropriate gamble. Fingers crossed.
Old Jan 4, 2018 | 07:09 AM
chazaroo's Avatar
Took the car in for headliner repair at Palm Park Auto Upholstery in West Palm Beach Tuesday. Got it back the same day and it's perfect! Not exactly sure of the process but they used the original alcantara and re-glued it. The guy there told me it should last as long as the original did. My $275 gamble paid off! If you're in South Florida and have this issue, call the folks at Palm Park!
Old Jan 4, 2018 | 08:19 AM
110reef's Avatar
Great deal!
I had a Mercedes '96 C220 with headliner issues and was quoted $700. Since I only paid $500 for the entire car, I never did do the job, and later sold the car. But I thought $700 was high.
Old Jan 4, 2018 | 01:56 PM
Sean W's Avatar
Glad it worked out. Any other solution guys have tried are nothing short of disastrous so replacement is the only way to go IMO. Glad you found a reasonably priced vendor too! Nice work.
Old Jan 4, 2018 | 06:15 PM
Hailers's Avatar
The headliner went kaput on two seperate '07 XK's I've owned. I removed them myself and reinstalled them myself. I took the headliners to a local auto upholstery shop and they had it ready the next workday. Around $100 bucks give or take five bucks.....Ft Worth, Texas.
Only problem with the re-installation was I put the left visor on the right side of the car and vice versa. That resulted in a drooping sun visor. Note; either visor will fit on either side of the car.
Old Jan 4, 2018 | 09:11 PM
multistrada74's Avatar
had it done on my former 2007, and it was 400 bux. hopefully it doesn't happen on my 2010. it has to be replaced. can't be fixed.
Old Jan 5, 2018 | 09:51 AM
chazaroo's Avatar
Why would it have to be replaced?
