Heated seat issue
Old Jan 9, 2022 | 08:50 AM
Khan's Avatar
Default Heated seat issue
My drivers side heated seat isn't working. If I set it to cool then the fan kicks on and it works. If I set it to heat I hear a click but then nothing happens. Anyone know where I should start with troubleshooting?
Old Jan 9, 2022 | 08:55 AM
Stuart S's Avatar
See the Workshop Manual. You can download it from the Sticky at the top of this Forum.
Old Jan 9, 2022 | 10:57 AM
Sean W's Avatar
Hmm, well the workshop manual could be helpful assuming @Khan is a DIYer.
The first question I would ask is are there any DTC codes? To do that you need a simple OBDII code reader. You want one that will read body codes and chassis codes, not just engine codes. I recommend this one
Amazon Amazon
Your going to want to start with DTC codes - depending on where that leads you,
Then manual check (you've done that)
Then test short circuit to ground
Then do a circuit continuity test
Test power consumption
Test Resistance
All those tests are in the workshop manual as Stuart guided you to, but you start with Trouble codes so you need a proper tool.
Old Jan 9, 2022 | 04:07 PM
Khan's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Test Resistance
Will do, thanks!
Old Jan 9, 2022 | 05:44 PM
Sean W's Avatar
thanks and let us know what codes you see.
POD XF
Nov 1, 2021 06:22 AM
adiayyala
Mar 31, 2018 07:56 AM
Jakepatch
Sep 7, 2017 04:27 PM
nasa25
Mar 20, 2015 07:43 AM
NTL1991
Oct 12, 2014 09:08 PM
