Help Alcon Brake replacement options
Old May 11, 2025 | 03:55 PM
XKDreams's Avatar
I believe my brakes are still OEM on my 40,000 mile ‘15 XKR. And I hate how much brake dust gets in my wheels, so I asked ChatGPT. Yes, this thread is Bout rotors, not pads.
“For your 2015 Jaguar XKR, which is a high-performance grand tourer, you’ll want ceramic brake pads that balance low dust, quiet operation, and solid stopping power—without compromising the refined character of the car.
Recommended Low-Dust Ceramic Pads for 2015 Jaguar XKR:
1. Akebono Euro Ultra-Premium Ceramic (EUR Series)
  • Designed specifically for European luxury/performance cars
  • Very low dust, rotor-friendly, and quiet
  • OE-level refinement and pedal feel
  • Ideal for daily driving and spirited cruising
2. PowerStop Z16 or Z17 Evolution Ceramic
  • Low dust and quiet performance
  • Good value for money
  • Suitable for street use, but not for aggressive track driving
3. Bosch QuietCast Ceramic
  • Known for consistent performance, low dust, and quiet stops
  • OE-style fit and performance
  • Great for balanced street driving
4. Wagner ThermoQuiet Ceramic
  • Quiet, clean, and long-lasting
  • Effective for smooth road use
  • Slightly less performance-focused than Akebono
Important Notes:
  • The XKR’s supercharged V8 and Brembo brake setup mean pad fitment must be exact, so verify that the chosen pad is specified for the Supercharged/XKR model and not the base XK.
  • If you do spirited canyon driving or occasional hard braking, Akebono Euro offers the best balance between performance and low dust.
  • Always pair new pads with a fresh rotor surface (resurfaced or new rotors) to get the most out of low-dust pads.
Then I asked her for matching rotors:
Since your 2015 Jaguar XKR uses high-performance Brembo brakes, you’ll want rotors that maintain braking effectiveness without generating excess dust or noise, and that match the clean operation of ceramic pads.
Here are some high-quality rotor options compatible with the XKR’s Brembo setup (typically 355mm front rotors and 326mm rear):
Recommended Rotors for 2015 Jaguar XKR
1.Centric Premium High-Carbon Plain Rotors
  • High-carbon metallurgy resists warping and improves heat dissipation
  • Plain (non-drilled/slotted), perfect for quiet, dust-free operation with ceramic pads
  • Very rotor-friendly and good for daily driving and spirited runs
  • Great match with Akebono or Bosch ceramic pads
2. Brembo OE Replacement Rotors
  • Same brand as your original equipment
  • Perfect fit and finish, with OEM-quality metallurgy
  • Excellent choice if you want to keep the car as close to factory spec as possible
  • Pair perfectly with Akebono Euro or other premium pads
3. PowerStop Evolution Coated Rotors
  • Zinc-plated for corrosion resistance
  • Smooth-faced rotors (not slotted/drilled)
  • Designed to work well with PowerStop ceramic pads
  • Good value option for clean, reliable stopping power
4. EBC RK Series Premium OE Replacement Rotors
  • Non-slotted, non-drilled for maximum pad contact and low noise
  • Designed for luxury and performance cars
  • A great fit if pairing with EBC Redstuff or Akebono pads
Avoid These (for Your Goals):
  • Cross-drilled/slotted rotors: while they look sporty, they tend to increase dust and noise, and aren’t necessary unless tracking the car.
  • Cheap unbranded rotors: can warp or develop hotspots quickly, especially under a heavy car like the XKR.
Old May 18, 2025 | 09:39 PM
Gomes's Avatar
Very interesting to see Ai never recommends slotted or drilled rotors just plain ones. I can get Zimmerman plain rotors but I was hoping to match to the crescent cutouts in the OEM and because my rears are only 10km old and have the crescent cuts I like it to match. perhaps its not a big deal to get flat plain rotors after all.
Oh side note fyi. Called two dealerships one in Vic and MCL Motors in Van were my rears were done. Jag vic 1527.00 per rotor lol... MCL was 1921.00 right and 1876.00 left rotor lol The dealerships are shameless ....
Old May 19, 2025 | 12:25 PM
McJag222's Avatar
Where are you getting the Zimmermans - I just checked their catalogue - it doesn't show Alcon rotors only pads:
Zimmerman Catalogue
I have drilled and slotted rotors on my Ford Sport Trac - work fine and I don't find them noisy.
Old May 19, 2025 | 12:30 PM
Gomes's Avatar
Zimmerman Catalogue
It’s just what my shop told me they could get but I’m thinking I go with what you have bought from Car iD. I have account with them too as I’ve ordered items for my old m3.
im still waiting for a final confirmation from Lordco on the Centrics availability…
DFC rotors I’ve never heard of but assume are good to go ?
Old May 19, 2025 | 12:36 PM
McJag222's Avatar
DFC seem to be kosher and US based, not sure if their discs are made in the US. I'm still waiting on delivery this week.
https://www.dynamicfriction.com/about-us
Old May 19, 2025 | 12:42 PM
Gomes's Avatar
My brembo Pads just arrived the other day.
I hope they’re the right ones. Alcons make life harder lol.
Old May 19, 2025 | 01:51 PM
McJag222's Avatar
According to the tech data sheet for the Brembo part number they list the JAG part number for Alcons.
C2P15994 JAGUAR
1610696480 PEUGEOT
Old May 19, 2025 | 04:49 PM
  #28
Gomes's Avatar
C2P15994 JAGUAR
1610696480 PEUGEOT
its from autopartsway in Alberta so I think its correct. The box says 06 jaguar xk- lol but that means nothing im sure
Old May 20, 2025 | 12:55 PM
David993S's Avatar
I agree with most of what XKDreams said, with the exception of cross drilled / slotted rotors. Of course they're beneficial on the track, but they can also be effective on the street. Are they necessary for the street? No, but the drilling helps cooling, and the slotting will help dissipate water and the slots help keep the pad wearing evenly. I have drilled/slotted rotors on my Jag and drilled rotors on the other sports cars. Never any issues with noise. Someone here said that drilling makes them crack more easily, but that's not true.
And if you want less brake dust, just go with ceramic pads.
Old May 20, 2025 | 02:56 PM
  #30
McJag222's Avatar
My front DFC rotors arrived - the rears were were mislabeled so they are re-sending them - no duties or tariffs out of the states. I guess they forgot to drill 'em.
Old May 20, 2025 | 03:49 PM
  #31
wymjym's Avatar
My XK brake experience has been ‘strange’.
I admit that when I use the brakes, it is either just slowing gently to a stop or heavy from elevated speeds.
Initially I installed PowerStop rotors with some ceramics included with the ‘kit’.
They started pulsating @ 12K miles.
I replaced those rotors with Brembo OE Replacement, they started pulsating @ 10K miles.
I installed Brembos again but am starting to feels a slight pulse, I have 4K miles on them.
Next time I’ll be replacing pads + rotors. Thinking Porterfield + Brembo.
Also, I only had one set of brake rotors crack in my many years of driving. They were on a 928S, and were Brembos that had been drilled. (not by Brembo).
So yes, they can crack!
and I definitely warped a set of front rotors on a Kawaski zx11 while doing a powerstop from 175 MPH. The rotors actually wobbled when placed on a flat surface.
wj
Old May 23, 2025 | 08:09 PM
  #32
Gomes's Avatar
Interesting they are not drilled, did you speak to them or you dont care ?
Old May 24, 2025 | 11:32 AM
  #33
McJag222's Avatar
I was surprised too. Didn't speak to them - just happy to get some spare Alcons for just a little over $1000 Canadian including shipping.
Old May 24, 2025 | 07:59 PM
  #34
Gomes's Avatar
May I ask how long did they take to arrive. ?
Id be the same as you, I need to order asap. im squeaking like a dying Pig.. Its brutal
Old May 24, 2025 | 08:59 PM
  #35
Gomes's Avatar
Came across this ??
https://www.crossdrilledrotors.ca/checkout/cart/
Old May 24, 2025 | 09:22 PM
  #36
Gomes's Avatar
Ignore looked up reviews and sounds like they are cheap crap
Old May 24, 2025 | 09:24 PM
  #37
McJag222's Avatar
Took around 10 days.
Old Jun 2, 2025 | 02:39 PM
  #38
Gomes's Avatar
Ok rotors arrived , I ended up and maybe I made a mistake to go with the crescent slots so they match the rears. Difference part number, not the premium but the way I drive it’s no issue. All looks good. Install is next Wednesday so can report back .. thank you Mj for all the info and everyone one else. Landed from Car ID ( I got hit with 54 bucks duties ) was around 500. 460 cad and duty. Pic below
Old Jun 2, 2025 | 02:42 PM
  #39
Gomes's Avatar
Here are the part numbers DFC and CariD
Old Jun 3, 2025 | 09:10 AM
  #40
David993S's Avatar
Why do you think you may have made a mistake? Good choice, IMHO.
