Help with hose ID
Old Jul 6, 2025 | 08:15 AM
DlsXK's Avatar
Default Help with hose ID
Hoping someone can clear my confusion. In need to replace these hoses and connector (2008 XK NA). I can see the picture in he parts catalog, but when I search the part number, it pulls up something completely different. Can anyone te me the part names and numbers,
thank you,
David L
Old Jul 6, 2025 | 10:59 AM
Sean W's Avatar
Here you go. I had the same problem earlier:
https://www.jaguarforums.com/forum/x...5/#post2843532
It's definitely leaking at the fitting. FWIW the brown crud on top of the hose is just the engine vanity cover insulation.
Old Jul 6, 2025 | 11:15 AM
DlsXK's Avatar
Default Thank you!
Thank you! Now to get get the 02 sensor and SIS to reset so I can pass emissions!
Old Jul 7, 2025 | 02:24 PM
sony2000's Avatar
I just replaced the rotten connector with a couple of inches of 3/8" copper tubing, from the plumbing store.
Old Jul 7, 2025 | 03:57 PM
Sean W's Avatar
not worth the savings imo. The clamp at his reservoir looks wonky too.
Old Jul 8, 2025 | 07:43 AM
sony2000's Avatar
The only defect is the straight connector. Mine just fell apart. Disintegrated plastic.
SharkGill
Feb 24, 2025 08:53 AM
Gates02
Apr 5, 2024 11:10 AM
wsn03
Jan 30, 2022 02:56 AM
XxSlowpokexX
Oct 14, 2020 03:44 PM
zidjan
Dec 21, 2019 10:38 PM
