High revs on startup, misfire all cyl, stalls, help
Old Apr 8, 2025 | 04:31 PM
ab763's Avatar
Default High revs on startup, misfire all cyl, stalls, help
2007 xk coupe 100,000 miles, when starting engine reves to 3000rpm, when put in gear it idles very rough, sometimes stalls when slowing down and pulling into a parking lot. I have replaced coils, sparkplugs, air filter airflow sensor, cleaned throttle body, changed throttle body for another, searched for air leeks, tried to clean egr valve, still no fix. what am I missing? Its 90 miles to the highest priced Jag dealer in Texas. Any help would be greately appreciated.
Old Apr 8, 2025 | 05:29 PM
guy's Avatar
guy
Codes?
I suspect there is a leak of some form.. or the ecm is acquiring the wrong data and compensating.
Old Apr 8, 2025 | 06:07 PM
Stuart S's Avatar
You don't need a Jaguar dealer to get the diagnostic codes. Any local independent ASE-Certified mechanic who works on European cars should be able to get the DTCs (Diagnostic Trouble Codes) and pinpoint the problem. Don't waste time and money by trial-and-error guesswork. Simply Google "independent European car repairs near me", read their reviews and make some calls. Good luck!
Old Apr 8, 2025 | 09:16 PM
sony2000's Avatar
Fuel pressure sensor, fuel filter.
Old Apr 9, 2025 | 06:41 AM
texas jag's Avatar
Where in Texas are you? I’m in Houston metro area, and have an indie I can recommend. PM if you are interested.
Old Apr 13, 2025 | 03:18 PM
ab763's Avatar
There are no DTC other than cyl missfire on all 8
Old Apr 13, 2025 | 06:59 PM
sony2000's Avatar
Temperature sensor may be finished. See if an OBD2 reader can access the reading of the engine, and cross reference it to your outside thermometer.
Old Apr 14, 2025 | 11:18 AM
JagV8's Avatar
High revs / stall may well be due to air leak(s).
Old Apr 14, 2025 | 03:31 PM
guy's Avatar
guy
Efficient root cause analysis is best served with the complete list of DTCs and the workshop manual in hand.
A generic reader may not necessarily expose all codes.
Old Apr 16, 2025 | 08:34 AM
Cee Jay's Avatar
Usually what JagV8 said; most of the time high revs and misfire on all 8 is because a pretty large vacuum leak
Childeric12
Dec 26, 2022 07:30 AM
NOFIS
Dec 6, 2020 06:03 PM
RFXJ12
Feb 23, 2017 01:39 PM
jagxk2008
Oct 13, 2016 09:25 AM
Roshan Naidoo
Sep 13, 2013 11:32 AM
