HighFlow Cats 4.2/5.0
Old Sep 22, 2015 | 10:51 AM
FrickenJag's Avatar
Former Sponsor
Originally Posted by ferraripete
looks like you are going to be producing some very nice bits of kit. I wish there were some goodies available for the naturally aspirated 4.2 liter...that needs to be woken up as well!!!
Pete, you're in luck sir. This XKR upgrade cat, fits the 4.2 XK as well. I know the Cat on the 2008 is the same for XK and XKR.
The headers that I'm building should mount up to the 4.2 as well. Instead of a 4-1 collector , I would suggest the Tri-Y design as the vacuum will really help the N/A engine exhale. I'm going to build a tri-y after I complete the current design.
Regards,
Derek Fricke
Old Sep 22, 2015 | 11:30 AM
ferraripete's Avatar
thank you for the response and good news. I would have bought an xkr but my car actually "picked me"
I would like to do all I am able in order to unlock some ponies! I will keep an eye out for this thread.
Thank you again.
pcb
Old Sep 22, 2015 | 11:40 AM
FrickenJag's Avatar
Former Sponsor
Thank you again.
pcb
The N/A units need love too. Both great cars. Thanks for the encouragement.
PS. 1983 Ferrari 512 BBi!!! You lucky dog.
Old Sep 22, 2015 | 04:27 PM
thanks and you are too kind
Old Sep 28, 2015 | 09:33 PM
bigdhenderson's Avatar
Derek, what are you using for the flange connection to the manifold? That's the one thing that stopped me from finishing my own custom high flows, after trying several different ones and not being confident with the fitment, I ended up modifying the stock cats for now. I want an OEM fitment and also something that wouldn't take a ton of modifying to make work. I'd greatly appreciate your input or even buy some parts if you have them available.
Old Sep 29, 2015 | 07:23 AM
Timmah!'s Avatar
Originally Posted by FrickenJag
My current intake replaces the factory lower piping segments to eliminate the resonators while also improving flow transitions. I'm working on a full carbon fiber smooth transition from throttle to air-boxes and air-horn. I will have these for the 4.2L and 5.0L soon. I'm in the process of finalizing the design then I'll create the molds for carbon fiber process.
I'm interested in this as well. Please keep me updated on availability if you plan to produce an upgraded intake for 2007 XKR.
Thank you.
Old Sep 30, 2015 | 08:48 AM
FrickenJag's Avatar
Former Sponsor
Henderson,
I cut a 3/8" stainless flange and used 18ga 304 stainless 2.5" flared to 2.875" roughly and the fitment is nice.
Old Dec 15, 2015 | 10:13 PM
  #28
FrickenJag's Avatar
Former Sponsor
I'll have them test fitted and welded up shortly. Tacked everything together. All will be tig welded and optional coated. All stainless construction. I'll do some weight comparisons as I noticed they were quite lighter.
I will have 2 Cat options: one with Race spec 200-cell and one Race spec 300-cell that EPA certified in 49-states and no cell light.
Old Dec 16, 2015 | 07:13 AM
kj07xk's Avatar
I'll bet you're saving the before and after comparison numbers for a 'big splash' promotion when they are finalized, but out of curiosity, how many 'cells' in the OEM cats?
Old Dec 16, 2015 | 06:49 PM
  #30
Looking great Derek! I see they reduce where it would meet the mid-section. Is that supposed to slip in the stock mid section then? What's the diameter before the reducer 2.5"? Keep up the good work
Old Dec 16, 2015 | 08:48 PM
  #31
FrickenJag's Avatar
Former Sponsor
Thanks guys.
I need to cut open the factory to verify, but I believe the front portion is a 600 cell and rear portion of the catalyst is 400 cell.
Yes this is designed to slip directly into the factory pipe. Its an oddball side, I had to swedge it down to the ideal diameter of 2.100". Roughly 53.5mm OD. I couldn't find any off the shelf items to fit. a 2.125" is too tight and 2" too small.
One of the local members here will be mounting them in for some comparative data.
Keep in mind, the main gain here will be the acoustic pleasure to your ears. There will be a gain in the lower torque region but we are still restricted more-so by the manifold. 5-10whp and roughly same with torque is what we are expecting on a completely stock setup.
Pully+Tune setups may see a little more gain.
I'm testing fitting them up asap then I'll finalize the welding.
The XK , XKR setups will be ready to start production by the end of the week.
I'm ready to build the F-type V6 and V8 Setups just need to locate tooling for the connections.
Old Dec 17, 2015 | 10:30 PM
  #32
FrickenJag's Avatar
Former Sponsor
Bolting them onto a members car tomorrow for test fitment. Once verified they will be nicely tig welded and ready for my seal of approval.
4.2 XK and XKR setups will be ready for sale shortly. F-types V6/V8 are right behind these.
Old Dec 17, 2015 | 10:44 PM
  #33
Cambo's Avatar
...I believe the front portion is a 600 cell and rear portion of the catalyst is 400 cell.
Yes that's my understanding as well.
...There will be a gain in the lower torque region but we are still restricted more-so by the manifold. 5-10whp and roughly same with torque is what we are expecting on a completely stock setup.
The gains also depend on the condition of the cats you are replacing, when my XJR had choked cats & we put the 100 cells on, it was like the car had picked up 50hp or so.
In reality it only really came back to just above it's original power levels, but the immediate difference was like a slap in the face, the performance of the car had degraded slowly over time that it was not really noticeable. But when the power came back with the new cats it was a halleluia moment.
Old Dec 19, 2015 | 12:48 PM
  #34
FrickenJag's Avatar
Former Sponsor
Cambo brings up a very good point. Cats do tend to lose their efficiency with time. So those with a few more miles, may notice quite the benefit.
They bolted up quite nicely. I'm going to finish up the welds so they are nice and pretty inside and out. During the Tig process we purge the inside of the tube properly so that they weld gets nice penetration and the finish on the interior side of the piping is smooth as well.
Stock converters for XK and XKR both weigh in at 10lbs each, 20lbs total.
These weigh in at 5lbs each, for a total saving of 10 lbs. (Every little bit counts )
I'll do some db reading before and after shortly for the 200 cell.
4.2 XK / XKR setups are finalized.
There are some sound clips of a 2008 XKR with the 3" setup I build last winter with the same 200 cell converters on youtube.
www.youtube.com/watch?v=HEGPXsOMXrw
Old Dec 28, 2015 | 02:11 AM
  #35
Cambo's Avatar
Do I see an H-Pipe in the exhaust, right after center section pipes come close together?
Old Dec 28, 2015 | 10:34 AM
  #36
FrickenJag's Avatar
Former Sponsor
Yes sir. Something that is on Emerson's car currently. I'll be sure to get some sound and db readings shortly. Both before and after 200 cell install. I'll compare it to the x-pipe with 200 cell.
Old Dec 28, 2015 | 10:55 PM
  #37
watching this thread closely.
Old Jan 11, 2016 | 11:02 PM
  #38
FrickenJag's Avatar
Former Sponsor
Both XK and XKR HighFlow Catalytic Converters are complete!
Improve Performance & Sound of Your Jaguar XK and XKR.
Get high-performance and sound for your Jaguar XK or XKR by replacing the restrictive 600 cell Catalyst for a 200 cell FrickenFast High-Flow Catalytic system. Not only will you get an instant increase in horsepower, torque and throttle response, but FrickenFast’s complete catalyst system will give your Jaguar a ferociously wild and deep performance tone. This system was specifically developed for the Jaguar owners looking for a deep muscle and exotic sound. FrickenFast Catalyst system bolts on right in place of your stock catalyst system with ease. These high-flow 200 Cell catalyst reduce back pressure substantially and increase flow rates allowing the engine to exhale more easily, which equates to more power.
Kit Details:
• High-Quality Construction
• ½ the weight of the factory system
• 304 Stainless Steel Mandrel Tubing with brushed finish
• Nicely Tig-welded
• Pipes purged properly during the welding process for smooth surfaces internally.
• High-Flow Cats (200 Cell) Spun Metallic Catalyst
• 49 State & Canada Emission compliant.
• (*A 300 Cell High-Flow Cali Certified Catalyst is optional with similar flow rates)
• Direct factory replacement with no modification to mid-pipe.
• All Necessary Hardware & Instructions
• Unlike multi-piece cats with ceramic cores, this cat will never leak or crumble.
*This system bolts in easily with the use of two jack stands and 45 mins of your time*
Retail: $ 1850
Jaguar-Forum Member: $ 1750
Jaguar-Members Special for 1-Month (Sale ends Valentines day) : $ 1650
Sounds clips and video will be taken tomorrow.
Old Jan 20, 2016 | 06:29 PM
  #39
FrickenJag's Avatar
Former Sponsor
XK and XKR 2007-2009 guys.
This is the first production unit I used to verify fitment and sound. They were mounted up and tested for 30 mins and taken back off.
If anyone is interested in this set, I am discounting them to $ 1000. Only stipulation is, Send me a couple sound clips
If you would like them ceramic coated I can get pricing for that as well.
2010-2015 Guys, I'm wrapping up the design for these units shortly. First test fit-up on these units will be with a XKR-S out of Atlanta. Very excited to hear the end result for this model.
Old Jan 29, 2016 | 07:14 PM
  #40
Johncy2000's Avatar
I dream of having HFCs on my 2012 XJL SC one day but I'm afraid I'm +hit out of luck...
